Civic 96 obd2 running with a obd1 ecu?is it possible?
Old May 5, 2009 | 02:17 AM
baulum's Avatar
Default Civic 96 obd2 running with a obd1 ecu?is it possible?
Hi,I've a civic 96 d15z4 engine non vtec with a stock ecu P2E Obd2 and i am wondering if i can use a obd1 ecu using a conversion adapter harness?Is it possible to use a P28 obd1 chipped ecu.Thanks.
Old May 5, 2009 | 03:05 AM
inspector01's Avatar
Default Re: Civic 96 obd2 running with a obd1 ecu?is it possible?
Yes.
Old May 5, 2009 | 06:50 AM
hmoobhero's Avatar
its possible but your engine has no vtec...p28 is a vtec ecu. so theres no point and you prob will get a CEL.
Old May 6, 2009 | 01:46 AM
baulum's Avatar
you are right i've completely forgotten the vtec.So should i buy a P06 or P08 ecu which has no vtec setting but the ecu needs to be chipped as i want a 8200 rpm instead of the stock 7200 rpm.
Old May 6, 2009 | 02:31 AM
94EG8's Avatar
Seagull Management
The P08 is still a vtec ECU (JDM D15B Vtec) the P06 isn't though. If you're planning to rev a stock d-series (especially a non vtec one) to 8200 don't expect it to last long. Its not making power past around 6300RPM anyway so I really don't see the point.
Old May 6, 2009 | 03:06 AM
baulum's Avatar
I'll not rev it to that extent but i just want to pass 7000 rpm,this won't be everyday.7500-7700 should be right?So which ecu should you guys propose?
Old May 6, 2009 | 04:58 AM
When it is chipped, you change everything anyways, so you can disable vtec, so it doesn't matter what ecu it is. There is no point in revving past stock redline, you will have no power at all, and it will just slow you down and damage your engine.
Old May 7, 2009 | 10:37 PM
baulum's Avatar
Actually i am preparing the ecu as later i'll upgrade my camshaft.I'll not rev it to 8000 rpm until i get my camshaft and valve springs installed.But right now i need a chipped ecu.So,i'll look for a P28 or a P06 tuned according to my specs.Thanks everyone for your valuable help.
dsmh8tr
Aug 27, 2008 07:13 PM
Neptronix
12
Jan 25, 2008 08:06 AM
saywhat
10
Dec 19, 2004 06:57 PM
compwc18
Feb 21, 2004 06:07 PM
