Worst night of my life - misshifted
Old May 4, 2009 | 10:34 PM
H.I CTR's Avatar
Icon2 Worst night of my life - misshifted
last night i was opening up my car on the highway. as i was going from 3rd to 4th my car started to bog slightly, then it back fired then it reved to like 9k as if i was putting my car from 4th into 1st and slowly came to a stop..anyone know what happened? my car doesnt start anymore. sounds like it doesnt have compression. my friend said he heard it and it made the sound like the time his bros crx dropped a valve..i thought i made the timing belt slip, but i didnt. there was no hole in the block or leaking oil..anyone know what this is? please help me out asap..tomorrow i am planning to take off the head..hope i dont find anything fcked up
Old May 4, 2009 | 10:43 PM
H.I CTR's Avatar
Default Re: Worst night of my life
bump..need some help
Old May 4, 2009 | 10:47 PM
H9Omega's Avatar
Check the timing, do a compression test. After that, drop the oil pan and inspect bearings/rods.
Old May 4, 2009 | 10:51 PM
H.I CTR's Avatar
u can check the timing even though the car cant start? is there any way to do a compression test without using the tester?..sorry im a noob to this car stuff..if i cant do it, my dad wants a shop to fix it
Jimmy's Avatar
Global Moderator
Drain the oil and check for metal shavings also.
Old May 4, 2009 | 10:52 PM
H9Omega's Avatar
Default Re: Worst night of my life - misshifted
Line up the crank pulley with the marking on the bottom, and see if the cams line up, search around the forum for the how-to and good luck man.
Old May 5, 2009 | 06:06 AM
ic's Avatar
ic
prepare to pull the head.
you bent your valves.
Old May 5, 2009 | 06:11 AM
thumper64's Avatar
Check the tension on your timing belt. If it's loose, you probably skipped a couple teeth...
Old May 5, 2009 | 06:24 AM
EG6KILIN's Avatar
For some reason do you have a b16? Because my friend did the same an he endednup messing up a valve so he replace them all with skunk2
Old May 5, 2009 | 09:19 AM
judgement_jdm's Avatar
ok dude if ur car doesnt start that means u either have bent ur valves or crack pistons. cus if u mis that really kills the motor.. and its really hard to pop it back to 1st gear once ur in 2nd or all the gears.
Old May 5, 2009 | 11:09 AM
American.Graffiti's Avatar
I agree as well.
Old May 6, 2009 | 11:38 PM
H.I CTR's Avatar
Ok..headsup..i found out that the timing is off..me and my friends are going to try and reset the timing and go from there..
Old May 7, 2009 | 12:00 AM
sp00ledbseries's Avatar
That sucks. why is there so many mis shift threads lately
Old May 7, 2009 | 05:38 AM
cadeMFjohnson's Avatar
if the timings off, u can bet that it didnt go out of spec peacefully.. it took motor parts with it
Old May 7, 2009 | 05:48 AM
Bense's Avatar
I'm sure it's fine, just like my f20b was:
Old May 7, 2009 | 06:05 AM
lponcian5799's Avatar
^^^major ouch
Old May 9, 2009 | 11:25 AM
H.I CTR's Avatar
thats messed up..i hope my motor isnt like that
Old May 9, 2009 | 11:35 AM
DualCamEJ's Avatar
ouch, i guess you should of change your timing belt.
thats what happened to my y8
Old May 9, 2009 | 11:39 AM
XKINGX's Avatar
how do u know by what his description says. lots of things could have happen. he needs to to do what the guys have told him first. check timing, check compression then if thats junked up drain oil and pull the pan and look for **** salad in the pan.
Old May 9, 2009 | 11:41 AM
H.I CTR's Avatar
this happened cause u didnt change your timing belt?
Old May 9, 2009 | 11:43 AM
XKINGX's Avatar
I would change the belt anyway... it slipped for a reason and it could be because the belt is old and stretched.
Old May 9, 2009 | 01:56 PM
EJ1_Sleeper's Avatar
dude, if your belt slipped and you havnt messed with it at all, and you were in 3rd going to 4th, you really just need to drain the oil, and if you see metals shards then pull the head. Slipped belts NEVER end well.
Old May 9, 2009 | 02:25 PM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
Originally Posted by Bense
thanks for providing me with a picture to match my nightmares....
Old May 9, 2009 | 03:41 PM
TravisCadello's Avatar
check for compression. probably valve problem or even worse.
Old May 9, 2009 | 03:44 PM
Pothole987's Avatar
looks similiar to my trucks old motor... Some bondo should fix that Right up
