FS:Built GSR motor
I have a built gsr long block for sale and some parts. GSR BLOCK has golden eagle sleeves w/ copper ring, aries 10:1 flat top pistons 83mm bore, golden eagle rods big bolt has about 1k break in miles- for$1600 GSR HEAD has skunk 2 pro series springs and retainers and super tech valves and new valve seals and guides stock cams- for$1000 Elderbrock manifold with 68mm professional products trottle body and 4 bar hondata map sensor- for$300 skunk 2 jumper OBD2 to OBD1 harness for 01 integra- for$50 Berg Warner S372 turbo has 2 dyno passes on it- for$1000 AVID solid motor mounts brand new for integra or eg civic- for$225 ARP head bolt- for$50 the head and block are together right now with the arp head bolts and cometic head gasket- for $2600
AnT PERFORMANCE
Aug 5, 2011 06:06 PM
95 integra
Mar 21, 2005 08:22 PM
