Is Oil cooler standard on B16 1st gen??
Old Aug 17, 2002 | 02:13 AM
evo's Avatar
evo
New User
Default Is Oil cooler standard on B16 1st gen??
My friend told me it has oil cooler, but it use the coolant instead by air, is this true?
Old Aug 17, 2002 | 06:47 AM
E-AT_me's Avatar
Default Re: Is Oil cooler standard on B16 1st gen?? (evo)
yes, most honda's do. look at where the oil filter mounts, if you can. you'll see two coolant lines running from it's mount..
Old Aug 17, 2002 | 07:59 AM
SqueezinEF's Avatar
Default Re: Is Oil cooler standard on B16 1st gen?? (Rexman)
Old Aug 17, 2002 | 11:03 AM
evo's Avatar
evo
New User
Default Re: Is Oil cooler standard on B16 1st gen?? (SqueezinEF)
The coolant around 80C degree when engine warm, what's the point of that oil cooler more like warmer rather than cooler..
Old Aug 17, 2002 | 03:46 PM
primoEF's Avatar
VTec engines have the cooler
Old Aug 17, 2002 | 04:29 PM
Chiovnidca's Avatar
Sorry, but I have to be picky. Most Hondas don't have the oil coolers. Just the higher horsepower models do.
Old Aug 17, 2002 | 04:31 PM
Chiovnidca's Avatar
Oil runs alot hotter than the antifreeze. 350F to 400F isn't unheard of.
Old Aug 17, 2002 | 06:52 PM
E-AT_me's Avatar
Default Re: Is Oil cooler standard on B16 1st gen?? (Chiovnidca)
true, but what do you mean by higher horsepower motors? i know ZC's had them...
Old Aug 17, 2002 | 07:09 PM
coasterlvr's Avatar
U.S. b16's don't have them. I bought new hoses from a Type R.
Old Aug 17, 2002 | 07:12 PM
HybridFiend's Avatar
The JDM B16/ZC, have the oil cooler, the Delsol B16 doesn't have one, but the 99-00 Civic Si has one, the B18C/C1/C5/specR have them. The B18A/B don't have them. Anyway, there more for initial startup to help get the oil to normal operating temp. But they also keep the oil regulated to a normal temp too, since the radiator radiates heat.
Old Nov 19, 2002 | 01:42 AM
irev210's Avatar
Default Re: Is Oil cooler standard on B16 1st gen?? (HybridFiend)
my 88 HF has one
Old Nov 19, 2002 | 06:29 AM
JoshDM's Avatar
Default Re: Is Oil cooler standard on B16 1st gen?? (sirhatchback)
lets see some pics of these "oil coolers"
Old Nov 21, 2002 | 07:59 AM
rice_classic's Avatar
Default Re: Is Oil cooler standard on B16 1st gen?? (JoshDM)
So if you have a jDm b16 with a standard oil cooler would it be necassary to install a remote oil cooler for HPDE's at Laguna seca or will the standard one be sufficient?
Old Nov 21, 2002 | 08:02 AM
E-AT_me's Avatar
Default Re: Is Oil cooler standard on B16 1st gen?? (rice_classic)
yes, i would if i were you.
it does make a difference..
Old Oct 30, 2005 | 05:31 PM
chadmasterc's Avatar
Default Re: Is Oil cooler standard on B16 1st gen?? (E-AT_me)
Back from the dead, Im about to put my b16 head onto a ITR block that I just picked up. I noticed that the ITR block doesnt have the cooler on it(someone took it off for use on another engine).
Will my b16 oil cooler bolt up to the type R block?
I just noticed that the oil cooler was missing tonight when i put the shortblock on the engine stand.
Old Oct 30, 2005 | 05:55 PM
Default Re: Is Oil cooler standard on B16 1st gen?? (chadmasterc)
nevermind, I had the oil cooler confused with the breather chamber. Ill just try to put the b16 on onto the ITR block and go from there.
Hanmin
11
Apr 25, 2009 09:18 PM
welfarepc
Jan 10, 2007 10:26 AM
jdmcivicb16a2sc61
Jul 23, 2006 05:54 PM
blykins
Jul 25, 2003 09:59 AM
