Factory Type- r pistons vs JE pistons
im doin a high boost motor and am lookin for some advice i have a type r bottom end and i am re building it before i do the setup which pistons would be ideal for my build
Thanks for the input
the cr all depends on what your goals are and your boost levels but around 9-9.5:1 is always recomended.. the piston brand is all prefrance some say JE some say Wiesco, CP, Arias what ever looks the best for you or a shop with a good background recomends
Im running cp 9:1 with manley rods in my gsr block. Im not running the gsr specs I swapped to the ls 89mm stroke. Im running 24 psi around 560hp.
