H22 throttle body
Old May 4, 2009 | 07:45 PM
HseriesWeaksauce's Avatar
Default H22 throttle body
I'm wondering what size I should go with for an all motor h22 build. It's and h22a and I have a euro r manifold and I'm wondering if I should go with 68 or 70mm throttle body. Also should I get one that's tapered to increase velocity? What brand makes a good one for the big block of honda? I'd mainly like the opinions of people that have builds that make 230whp+. Thanks in advance guys.
Old May 4, 2009 | 08:29 PM
JDMPoochie's Avatar
Default Re: H22 throttle body
70mm
Old May 4, 2009 | 08:32 PM
^^^^ This is what my shop has been telling me. The thing is I have heard 68 is what you want as not to lose velocity. What's your setup what numbers are you putting out?
Old May 4, 2009 | 08:44 PM
crazes's Avatar
Moderator
it depends alot on what your intake is.....if your runing straight ram air or if you have a v-stack it will change what you have running...some of the big boy h guys run 72mm but that depends on what your running...just make sure whatever size you get your TB that have the IM match it as well
Old May 4, 2009 | 09:38 PM
I running a Euro R manifold with an AEM true cold air hybrid intake.
Old May 5, 2009 | 06:17 AM
98vtec's Avatar
moderator emeritus
im still running a 62mm s2000 throttle. One of these days i will test a bigger throttle, but for now it gets the job done.
Old May 5, 2009 | 12:19 PM
crazes's Avatar
Moderator
for me a choose a 68mm. i would have gotten a 70 but rosko suggested that 68mm is fine cause if he match it the euro-r mainfold it would leave the walls on the entry way really thin... i don't have numbers yet but thats what he told me...i know 2fastgsr when he had his 2.6 was running like a 72mm if i am not mistaken and so was hah2b..look at there builds to give you some help.
Old May 5, 2009 | 10:18 PM
BigBlock22's Avatar
im going 74 since i bought some 89mm wiseco's and plan on running almost 12:l cr. going for 250whp...... im an optimist
trade some bottom end in for the top
Old May 6, 2009 | 04:52 AM
GhostAccord's Avatar
OP my question to you is,
What other mods are you planning on doing to the engine other than the Euro R manifold? You don't mention any internal mods. Why does your shop, figure you would need a 70mm throttle plate?
My suggestion would be for you to get the engine up and running with the stock throttle body and see if it is pulling vacuum at WOT. If it doesn't pull vacuum with the stock 60mm then you probably wouldn't want to waste your time with a 68-70mm. If your not doing any major internal mods don't waste your time getting anything bigger than 62mm-65mm.
Old May 6, 2009 | 06:21 AM
JDMPoochie's Avatar
i did 227whp wit velocity stack blox 70mm and skank2 manifold.
Old May 6, 2009 | 08:38 AM
Did you make a run with a stock 60mm or a 62mm throttle body to compare to the 70mm?
Old May 6, 2009 | 04:46 PM
JDMPoochie's Avatar
just got the car tuned on the 70mm
Old Sep 16, 2009 | 03:47 PM
hdragster's Avatar
What did you push out?
Old Sep 16, 2009 | 09:12 PM
JDM JEFFREY's Avatar
i used a 76mm
Old Sep 21, 2012 | 06:21 PM
parthbla000's Avatar
would coupling a skunk2 IM and a 70mm TB produce better results than a Euro R intake with a 70mm TB? Either way modifications will need to be made in order to even bolt on a new IM on my prelude. Just curious of which one should yield better results.
Old Sep 21, 2012 | 07:21 PM
gstrudler's Avatar
There are some dyno's floating around comparing the intakes, but from what I remember and knowing the manufacturers, the S2 will likely outperform the Euro-R on the top-end, but the Euro-R will have better midrange and better power under the curve unless you are revving the motor out.
turboedsupe
Oct 23, 2008 01:36 PM
H22CD7
Jun 3, 2007 09:26 AM
lude98SH
21
Apr 23, 2007 09:33 PM
LUDEacris
20
Nov 1, 2006 10:49 AM
JDiMageDC2
May 23, 2003 11:12 AM
