VTEC cross over at different rpms
Old May 4, 2009 | 05:17 PM
DC-2guy's Avatar
Default VTEC cross over at different rpms
ive noticed that my VTEC crosses at a different rpm when i go threw the gears. it ranges anywhere from 4200 to 5300 going from first threw fourth gear. any suggestions on what i should look for or is this a common variable for the engine
Old May 4, 2009 | 05:19 PM
Brice.Hayden's Avatar
Default Re: VTEC cross over at different rpms
depends on what motor and what ecu.
Old May 4, 2009 | 05:21 PM
TunerN00b's Avatar
B18C1 transitions over to vtec between 4,400 RPM (or is it 4,200 RPM, my memory is failing right now) and 5,000 RPM, depending on throttle position (and possibly load, wish I knew for sure on that one though).
So, its normal.
How are you identifying the transition though? Most people can't hear or feel the transition, just the secondaries opening later.
DC-2guy's Avatar
im running a stock GS-R with stock ecu
Old May 4, 2009 | 05:23 PM
DC-2guy's Avatar
LOL the car has an unruley loud fart can on it. came with the car not my preference im an RSR fan personally because it doesnt have to be loud to go fast
Old May 4, 2009 | 06:53 PM
KingKnight's Avatar
RS*R Invidia is what I'm running. Love it.
Old May 4, 2009 | 08:29 PM
I can audibly hear my vtec crossover on my gsr but i have a skunk2 cams and several other bolt ons. Mine hits around 4500, but my Mugen Cluster seems to read a little bit off. the IABs hit right at 6,000.
Old May 5, 2009 | 01:11 AM
SiLEnT_ST's Avatar
mine is liek urs too
im guessing it is normal
but now i have a chipped p28 ecu
n i made vtech to come in at 5,000rpm
so everytime at 5,000rpm it kicks right in
Old May 5, 2009 | 08:50 AM
k20em1's Avatar
what ecu are you running?
Old May 5, 2009 | 09:36 AM
the OP said a stock P72
Old May 5, 2009 | 09:38 AM
jai6's Avatar
check your oil level mabey
redline09
Jan 23, 2010 06:11 PM
madcrx69
May 27, 2009 12:35 PM
EFboosted
Oct 14, 2008 01:18 PM
C1power
Jan 3, 2006 07:15 PM
