Suspension & Brakes Theory, alignment, spring rates....
Will i have any issues putting 99 si suspesion on a 95 integra?
Old May 4, 2009 | 03:24 PM
Turbo R's Avatar
Default Will i have any issues putting 99 si suspesion on a 95 integra?
Next weekend i plan on swapping suspension with my friend who has a 5 lug conversion on his 95 integra. Im putting the 5 lug suspension on my 99 si and im giving him my suspension.
Will there be any issues? ABS? E-Brake?
Thanks
Old May 4, 2009 | 05:06 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Will i have any issues putting 99 si suspesion on a 95 integra?
You will have to use washers between your rear shock lower forks and the LCA bushings, and he will have to grind the bushings on his LCA's to get the Si suspension to fit (and then have to use washers in the future if he goes back to Integra shocks).
LCA's are different lengths, so don't try to swap those.
/thread
Old May 5, 2009 | 07:52 AM
Turbo R's Avatar
im not swaping out the shocks or lca's.
i think he might not be able to run abs.
anyway to turn the abs light off?
Old May 5, 2009 | 12:02 PM
94eg!'s Avatar
#1 Super Guy
Loved
He should be able to move the abs sensors from his 5-lug suspension over to your 4-lug suspension. That is as long as your 4-lug rear hubs have the ABS ring. If not, he can buy new/used 4-lug hubs that have the ring.
On the fronts, the ABS ring is on the axles, so no worries there...
If he doesn't want to replace the rear hubs (if necessary), then you will have to unplug the ABS unit to turn the light off. At least that used to work on the older OBD-1 cars...
XxSOHCDriVerxX
Suspension & Brakes
Jul 10, 2006 10:42 AM
ernald711
Suspension & Brakes
10
Mar 6, 2006 10:46 AM
JDM CTR EK
Apr 29, 2004 06:37 PM
L8apex
Jul 20, 2003 03:30 AM
