Can anybody tell me where the other end of this is wired to
Old May 4, 2009 | 08:34 AM
es_squared's Avatar
Default Can anybody tell me where the other end of this is wired to
I had my motor rebuilt and a turbo kit installed, and the vtec is not engaging properly, but I think this may be the culprit. Can anybody tell me what this is for, and also where the other end of the other socket comes from? For the life of me I could not find the other end lol
http://www.flickr.com/photos/seansha...78150/sizes/l/
Old May 4, 2009 | 09:06 AM
218luder's Avatar
Default Re: Can anybody tell me where the other end of this is wired to
what year is your prelude? but from what it looks like that looks like the vtec wire to me.
Old May 4, 2009 | 09:33 AM
es_squared's Avatar
I hope to god this is the issue! Its 93 prelude. I checked my helms as well, but couldn't find it
Old May 4, 2009 | 09:51 AM
218luder's Avatar
check the vtec solenoid and follow that end of the wire to see where it goes.
Old May 4, 2009 | 09:58 AM
es_squared's Avatar
hmm, i will go check again
Old May 4, 2009 | 11:28 AM
es_squared's Avatar
Wires from the solenoid just go into a larger bunch of wires, guessing the main harness. Looking through my helms the socket is either C429 or C139. If its c429 I think it was plugged into the stock airbox? can someone confirm please
Old May 4, 2009 | 12:45 PM
jlude90's Avatar
is there anything plugged into the VTEC solenoid?
and does it go to the proper pin on the ECU for VTEC? i don't think YEL/BLK wires are for VTEC though
Old May 4, 2009 | 12:50 PM
pentaq's Avatar
This is not for vtec for sure. the one to the left is the vtec (grn/yel) and it's plugged properly. This one seems to be a connector for the test tachometer.
Old May 4, 2009 | 08:57 PM
es_squared's Avatar
there are a couple of wires from the solenoid, but as i mentioned they go into a large harness. ok so thats 2 for 'not a vtec related socket' lol thank guys
Old May 5, 2009 | 06:39 AM
Acidcrakker's Avatar
You know, its a black/yel wire.
Off the top of my head I forget if BLK/YEL wires are negative or positive.
I know that BLK/YEL and YEL/BLK are predominatly power or ground wires.
If it is a ground wire, it should plug into the grounding part of Vtec solenoid.
If I was you, I would just re-wire the Vtec in.
Old May 5, 2009 | 08:53 AM
Honda Sport's Avatar
looks like the connector to the OEM intake. when you take out the whole intake, the big resonator that's inside the RF of the bumper. if I'm not mistaken, it plugs into it.
Old May 5, 2009 | 03:58 PM
preludegofast13's Avatar
I havent dealt much with 4g's but I just wired up a b18cr in my 3g and black with yellow was 12v+ and being the plug that it is, it might be a coil pack plug if the white is tach signal.
Sohcrx 90si
Mar 22, 2015 01:17 PM
BUILT93ludeSi
Mar 4, 2008 05:09 PM
SOHC_MShue
Aug 22, 2006 06:43 PM
