gsr cant keep an idle (just dies)
i rebuilt my motor and put a skunk2 mani and now i have code #14 (IACV) and when i fist start the motor it idles fine at 1k then wen i took it around the block to break it in it starts to die on me everytime the revs come down to 1k..my IACV was fine wen i had the old gsr mani so idk.. any ideas?
you have two holes in that that check air in the maifold. clean them out. the two lines on the back side are for coolant. also, if your timing is off i can cause or help cause this. you may have a faulty iacv if you actually have a code for one. normally dirty ones never throw codes, your idle is just off.
yes the iacv has ports that check air most of the time they are clogged with carbon so try to clean it and check if all necessary vacuum lines r in place could also cause it
i cleaned the iacv and it still shows the cel.. i dont think a vaccum would trigger the cel. and i check all vacuum lines and the only one disconnected is from the purge valve to the evap can
i switched the plug..theres 2 plug that fit im guessing one is to the iacv and the other is for the thing that goes under the stock intake manifold i forgot the name...im gonna test and see if that fixed it 2morrow
joshua89
Aug 20, 2011 01:47 PM
the.hamburglar
May 10, 2007 08:46 PM
donkeypunch
Jul 18, 2002 10:43 AM
