Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
AC not working
Old May 3, 2009 | 08:39 PM
dayaftertomorrow33's Avatar
Default AC not working
I have a 2003 MDX and the AC is not working. The fan is blowing. I checked the psi and is 30psi. I checked the relay and it is fine. Please advice. Thanks
Old May 4, 2009 | 07:23 PM
dtapia's Avatar
Default Re: AC not working
what is the high side pressure readings while the system is on.
Old May 4, 2009 | 09:07 PM
how do I measure it?
Old May 4, 2009 | 09:24 PM
dtapia's Avatar
the same way you checked your low side readings. use the a/c manifold gauges and turn the a/c on and note your high and low side readings.
crewchief437
Honda Civic (2006 - 2015)
Feb 26, 2018 04:36 PM
David Guevara
19
Apr 9, 2016 06:44 AM
Single-Cam
16
Feb 10, 2016 07:23 PM
QuestMCoupe
May 17, 2012 10:39 AM
94LS_allmota
Jul 24, 2009 06:06 PM
