b16 setup help
Old May 3, 2009 | 05:57 PM
meheartmycivic's Avatar
Default b16 setup help
Civic 2000 si b16a2. right now has:
type r cams
type r header
type r throttle body
intake
straight pipe
greddy exhaust
high compression pistons
port and polish head
stage 1 racing clutch and light flywheel
japan spec obd1 ecu for b16
doin all motor. trying to get at least low/mid 13's. trying to reach 190 to 200+ whp. any suggestions to help reach goal?????? thanks
Old Jun 28, 2010 | 10:30 PM
poormanstyperb16's Avatar
Post Re: b16 setup help
type r cams
type r header
intake
straight pipe
greddy exhaust
dude i say high 13's at least but if not then mid 14's just like an integra type r. check my set up for a b16a2. my head is not port just a 84mm.
Old Jun 29, 2010 | 03:55 PM
jerryegk24's Avatar
Default Re: b16 setup help
Your gotta need better cams than type r,...header...What's the compression? Put some drag radial, weight reduction. Better ecu upgrade ratter than stock.
meheartmycivic
Feb 25, 2010 10:10 AM
meheartmycivic
Apr 21, 2009 01:25 PM
ej1252
15
Oct 25, 2007 04:26 AM
