Track Driven EF Civics Chime In
Old May 3, 2009 | 02:27 PM
Ludehrt's Avatar
Default Track Driven EF Civics Chime In
Hello Guys
I recently completed putting my B series swapped EF civic back together after a transmission rebuild and an alignment. I had a chance to take my Civic out to do an autocross and a NASA road course event without any trouble. Last night I decided to take it out and do some ¼ mle passes at the local drag strip and ran into some trouble. I had some serious wheel-hop on my first and only pass and I immediately noticed that my steering wheel was way off by about 45 degrees. I also noticed that the front wheels were way out of alignment – with some serious toe-out on each front wheel.
After doing a quick inspections of the tie rods/axels/suspension I went ahead and called it a night and drove it home and got it up on some jack stands for a closer look. I checked the sub frame mounting points, steering rack, inner/outer tie rods and they all seemed fine.
My question to you guys- Have any you EF guys ran into this issue where your alignment gets way off all of a sudden- especially after a bad launch or some hard driving? Is this a common problem?
Thanks in advance for your input.
Old May 3, 2009 | 02:40 PM
fireant's Avatar
Default Re: Track Driven EF Civics Chime In
Your fronts should be pulling towards toe in when you launch...wouldnt hurt to double-check the front radius rods where they connect to the subframe. The problem could also be in your rear suspension, and it happens when the rear squats.
89ED
Jan 20, 2019 09:28 PM
89ED
Jan 20, 2019 08:24 PM
SleepyEF
Jul 14, 2014 06:05 PM
Ludehrt
May 5, 2009 01:52 PM
slow hatch
68
Nov 10, 2006 05:22 PM
