d16 crank into a d15 block
i have a d1616 crank and i was wondering if it will fit into my d15b7 block. i wanna raise the compression of the d15. and if it does fit what rods do i use. im useing p2e pistons from a y7 bock.
well on the inside of the block were the bottom of the cylender walls are there is a bunch of small cracks in the block they look to be cracks anyways.. every other block that i have worked with ive never seen this untill this one. it has like 170k on it and 2 of the rod barrings were laying in the oil pan in little peices and were jammed into the oil pickup and pump itself. the crank main and rod journals are all scratched with the one with the destroyed barring being the worst.. i dont think its worth rebuilding
civic_mattattack519
Sep 10, 2006 03:35 PM
1320DRAGWORKX
May 12, 2005 05:13 PM
