Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Cruise Control Problem
Old May 3, 2009 | 01:21 PM
girliehonda's Avatar
Default Cruise Control Problem
I’m a new owner of a stock 2001 EX Sedan 5 speed. I’m having problems with my cruise control. I’ve only used it twice since I bought it. Now it is not working and I can’t figure out what’s wrong with it. The cruise control master switch button lights up but when I push the set button it won’t set. I looked to see if there is a cruise control fuse in the manual but found nothing. What fuse should I check? Has anyone run across this problem before? How should I go about getting this fixed? Is it ok for me to unplug the battery?
Old May 3, 2009 | 01:29 PM
dtapia's Avatar
Default Re: Cruise Control Problem
check on the clutch pedal and see if the rubber bump stop is broken. something is the system is open (ie) brake/clutch switch or the cruise control accuator is failed or unpluged.
Old May 3, 2009 | 11:41 PM
Eyger's Avatar
^He's right, there's a sensor which is associated with the clutch pedal, if the cruise control system thinks that the clutch is depressed, then it won't activate. I had a similar problem right after I had a security system installed with a remote start. The installer forgot to bypass the clutch sensor.
Old May 4, 2009 | 04:33 AM
Thanks I will check both pedals later today.
Old May 5, 2009 | 01:00 PM
I found out that mine take about 45 sec in order to set it. I’m guessing it doesn’t work like other cars I have driven before where you can set it at any time. Thanks again for everyone help.
Auxient
Apr 1, 2018 07:50 AM
bnewall1
Nov 19, 2013 12:01 AM
gripek
Honda S2000
Mar 18, 2009 11:58 AM
Sweetsystem
Aug 26, 2008 01:58 PM
Dezmon
Mar 9, 2007 06:38 AM
