Suspension & Brakes Theory, alignment, spring rates....
95 civic lean
Old May 3, 2009 | 12:45 AM
dave181's Avatar
Icon2 95 civic lean
hello ok this is whats going on my driver side has a lean on it and when u stand in front of the car u can tell big tim e not so much from the rear the car has stock suspension on it can anyone tell me y its like that i got the car like that also any help would apreciated thanks in advance
Old May 3, 2009 | 09:21 AM
dave181's Avatar
Default Re: 95 civic lean
bump
Old May 3, 2009 | 12:21 PM
FlatBrokeHatch's Avatar
Jack the car up, pull the wheel and check for a broken spring.
Old May 3, 2009 | 07:34 PM
dave181's Avatar
where would i look exactly or do i look at my stock springs lol could it be my shocks a blown shock at that i got tokico shocks im waiting for my lower control arms and im saving for coilovers also before i put anything on new can someone post a pick of exactly what i should be looking at thank you
Old May 3, 2009 | 07:44 PM
Yes...you should be looking at the spring itself. Once jacked up, first inspect it to see if you can visually notice it's broken, if not then try to move it around/up/down. I've never come across a broken spring but that's just what makes sense to me. If you don't notice anything wrong/broken with the spring itself, start looking around to supporting parts like the control arm, upper control arm etc and work from there.
Old May 5, 2009 | 02:21 PM
dave181's Avatar
ok will do thank you
Old May 5, 2009 | 03:42 PM
No problem, post what you find out.
Old May 10, 2009 | 07:19 AM
fanny's Avatar
New User
Default 93 civic
i replaced a upper control arm.when i was tighting it it seemed like i could go for days.i didnt kno how much to tightin it so i went as far as the codder pin an put the pin in.i dont kno if that is good enough couild some one maybe plz let me kno if that is alrite.also i half to replace a inner tie rod on it and i never did it b 4 should i try n do it myself.i'am a very confident person not cocky,i feel it just might b a bit to much for me.anyone with any help i would b very happy.thank you to any person who takes time to read my post.
Old May 11, 2009 | 08:35 PM
dave181's Avatar
the spring is fine and im not to sure what to look for wen inspecting the rest how do i post pics up ill take a pic and post it maby someone can tell threw a pic
agustintorre
Suspension & Brakes
13
May 17, 2012 07:20 AM
champwhiteEG6
15
Oct 23, 2008 03:46 PM
dthug
Suspension & Brakes
Jan 8, 2007 07:38 PM
mountaindewguy
Suspension & Brakes
Feb 21, 2005 10:58 PM
digitals
Dec 19, 2004 09:56 PM
