Front Sway Bar on Civic w/o stock sway
Old May 3, 2009 | 12:22 AM
HseriesWeaksauce's Avatar
Default Front Sway Bar on Civic w/o stock sway
I have a 99 civic dx coupe. It does not have a stock sway bar. I purchased a sway bar set from suspension techniques but purchased the wrong set. I purchased the set that was made for a civic with the stock front sway. What is the difference between the set with the stock sway and without. Can I just get parts from somewhere to replace whatever would have come in the sway bar set ment for civics without the front sway? Thanks in advance.
Old May 3, 2009 | 02:32 AM
waaBAAH's Avatar
Default Re: Front Sway Bar on Civic w/o stock sway
sure..you need ex or si lower control arms.
integra lower control arms would work as well i assume
B_quinhas
Suspension & Brakes
10
Aug 11, 2009 06:19 PM
BigBoulda
Suspension & Brakes
Sep 15, 2005 07:11 PM
Dragger817
Dec 21, 2003 12:11 AM
kungfuSiR
Nov 19, 2003 12:14 AM
