Looking for helpfull info on coilovers
Hey guys, looking to get a new set of coilovers and just looking for what everyone is going with these days..mostly street with ocasional track use..Thanks for your opinions..Oh yeah tried the search but got frustrated reading on accords..lol..
Im running Koni Yellow fully adjustable shocks and Skunk2 coilovers on my R right now. Sits and rides pretty nice.
(Pic of it pretty dropped but not slammed
The design of the coilovers likely have nothing to do with that, spring rates and damper matching (to the rates) is a far more likely suspect. A threaded sleeve coilover system with the same damper rebound/compression as a threaded body system and the same spring rates will be identical.
go to their website. picperformance.com
just call them first and talk to them if you want. Al is a great guy there. everyone here im sure that has bought PIC has talked to him.
btw there are a lil tricky to get used to, but once you have everything dialed in the are worth every penny spent
How much shock travel do you have in the front and aren't you're front upper control arms smashing into the shock tower every time you hit a bump?
Just curious becuase that ride height looks pretty low to be running on a set-up where ride height reduction = loss of shock travel.
the yellow teg with the white wheels above looks much more in line with what would work to keep the tires in contact with the ground over changebacks and daily driving.
i can understand f1 cars being that low because they are always on a supersmooth track going god knows how fast...but for a car that sees only crappy city streets and occasional track time that doesnt seem like the most ideal setup. just my .02 cents
FRKWOO
30
Nov 7, 2009 04:34 PM
Need_for_speed
Suspension & Brakes
Jun 20, 2008 10:52 AM
projectkleee
Suspension & Brakes
10
Aug 15, 2007 02:44 AM
