Wire tuck
that's a about right.we only had to cut about 10 different wires,some people don't like running them in the fenders because the tires can damage the wires.my car has a 2 inch drop and no problem
I have been thinking about this, but I dont really have the patience to do wiring lol. What engine is that Im a honda noob. H22?, I noticed the valve cover change, and I have never seen either of those, and I have a b16
i was only putting down 133hp to the wheel 123 tq to the wheel,with a b16 trans it moves quick.its a lot funner with boost its putting out like 210hp to the wheel
not to bash you but from what i hear and ive seen the orange valve cover is from the 96 and up ls motors. on the other one is from 95 and down. just from what ive seen
Also the orange valve cover is from a B18B, the first one is a B18A.
teg_95 is correct.
90-95 integras have what i call the waffle top,whether its a b18a or a b18b, 96-00 Ls has the valve cover thats painted orange...
BTW, this is in the wrong forum....IBTL!!!
I ran my wires through the frame. I don't have pics but there is a spot in the upper corner of the footwell that you can drill through to the frame rail that runs up to the front of the car. I ran my wires and the hood release, they are internal all the way up to the end of the frame right where the corner lights are.
I am having a problem with my 93 wire tuck it wont start any ideas i'm only getting the parking brake light in my gauge cluster seems to me like the computer isnt getting power or something.
Thanks
Bottomedoutcivic
Thanks
Bottomedoutcivic
i thnk his talking about that hollow hole you have on the frame that is hidden under your fenders. take your fenders off and youll see a hole tht runs up your front headlights from the doors
so where did you run the wires threw on your car? did you use the hole thats already existing into your cabin? or is it tucked into your fender.
why is your strut bar sitting so high?
i have a question im doing the tuck on my CRX with a d16z6 i got rid of my entire A/C system and heater core, where do i run the 2 hoses that went into the heater core? can i run it as one hose?
