gsr in eg help!!
Old May 2, 2009 | 07:40 PM
mxracer420's Avatar
Default gsr in eg help!!
ok so i have a 92 hatch with a b18c1 and i put the motor in got everything hooked up and checked it more then twice. it was throwin some easy to fix codes until i pinned in the knock sensor. and they all went away. vtec is kicking in and everything but its basically u coukld say has no ***** its wayy slow.. what could it be? its till runnin off open header could this be bad? no codes what so ever
Old May 2, 2009 | 07:55 PM
BigAnteg's Avatar
Default Re: gsr in eg help!!
running open headers will lack alot of power on a import with out turbo right now im having problem with my iab since im running a p28
Old May 2, 2009 | 07:56 PM
BigAnteg's Avatar
i dont if im lack power to
Old May 2, 2009 | 07:57 PM
beaneg6's Avatar
you should not lack power even open header, what ecu are you running? it could be possible that your iab's are not opening...
Old May 2, 2009 | 08:14 PM
mxracer420's Avatar
a p72. and thats what we though so i checked the vacuum and its all hooked up. so idk.. im just relly confused and frustrated.
Old May 3, 2009 | 09:40 AM
mxracer420's Avatar
ttt
Old May 3, 2009 | 12:02 PM
mxracer420's Avatar
before vtec and partially through till bout 6400 the motor has no power and then once that mark it starts to pull better. and my plugs are basically white whats my problem im lost.....
Old May 3, 2009 | 12:13 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Exactly how dos one "run open header" and have a turbo? You're making it sound like "running open header" is better with a turbo. Do you understand why I'd point this out?
ANYWAYS...
To the Op:
Have you checked the timing yet? i don't just mean ignition timing that's adjusted at the distributor, but also the timing belt/cam/crank timing. It's possible to have the belt off a tooth or more and run terrible, yet throw no codes.
Do you know how to check the timing belt timing?
Old May 3, 2009 | 01:22 PM
mxracer420's Avatar
not really no. like i have s budy comin over in a few ill ask him to check it hes a certified honda mechanic. but like i got the motor from hmotors and then put a new water pump and timing belt on it, so its possible but idk. lol.
Old May 3, 2009 | 05:31 PM
mxracer420's Avatar
so had my buddy come over figured out it was off a tooth thank god it didnt break anything or bend lol
Old May 3, 2009 | 06:01 PM
iwanttokillgod's Avatar
timing
Dioxine
Nov 17, 2011 06:34 PM
meallout
Jul 30, 2008 02:56 PM
EGLUVN
Jun 27, 2007 12:11 PM
roadracer321
Oct 12, 2006 12:58 PM
kraig8
Dec 18, 2005 02:10 PM
