Keeping a/c in b16 ek with del sol bracket
Old May 2, 2009 | 12:50 PM
c0d0r's Avatar
Default Keeping a/c in b16 ek with del sol bracket
Ok, I put a b16a into my 96 dx coupe using the del sol bracket to mount my compressor up to. My question is, can I re use my d series idler pulley and bracket/adjuster screws? How did any of you guys do it? Please help, it's like 95 degrees here and i'm missin my a/c!
Old May 2, 2009 | 02:13 PM
DerrtyByrd's Avatar
Default Re: Keeping a/c in b16 ek with del sol bracket
im not sure... but when i did the b16a sir2 swap into my 96 EJ8 they said the only way i would have ac is to get everything from the 92-93 delsol w/ the b16. The pulley ur tryin to use would be the right size. I didnt car about ac at first cuz of the few extra ponies u get... but i understand ur pain. my car isnt a track car right now so my comfort is more important. good luck wit that one and try to stay cool.
Old May 2, 2009 | 02:24 PM
sliverek9's Avatar
when i swaped my 00 ek i reused my ac compressor and lines fromm my d16 on my type r motor that i installed and my friend showed me how to hook up the d series compressor on the type r motor with out using a del sol ac bracket the first two bolts on the d series compresor will bolt up to the b series bracket just fine and everything works perfect just buy a b16 ac belt and install it and you will have ac. now im not to sure on the tensioner pully but i just got one off of a old ls block my friend had laying around and used it. i can send pics to show you how i have mine installed if that would help
Old May 2, 2009 | 02:35 PM
c0d0r's Avatar
silverek9, if you want to you can send me some pics! Any help would be great, I miss my a/c!
My email is ricerkiller@gmail.com
Other than that, anyone else?
Old May 2, 2009 | 05:26 PM
c0d0r's Avatar
anyone else?
Tomorrow's gonna be a scorcher!!
Old May 2, 2009 | 10:25 PM
hOnda_hiEn's Avatar
when i had my gsr in the ek.. i used a crv ac bracket.. it came with the idler pulley though.. doubt you could you the d series pulley..
Old May 2, 2009 | 10:26 PM
XKINGX's Avatar
no u cant use the pulley off a d series bracket on a b series. you mod a b series to fit a d series compressor
Ecky
13
Feb 22, 2014 03:15 PM
mgrcrx
Jan 16, 2014 03:45 PM
jdmvtecej2
Sep 7, 2008 01:39 PM
powderb18b
10
Jun 21, 2007 07:03 AM
LXguy
Feb 6, 2002 12:00 PM
