May FS Sticky. please read rules
Old May 2, 2009 | 03:40 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default May FS Sticky. please read rules
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for
RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
__________________
Old May 2, 2009 | 05:30 AM
denske's Avatar
Default Re: May FS Sticky. please read rules
2 omc coils, with msd wires. 150 shipped
90mm nissan throttle body, comes w/ tps. good condition. 100 shipped
Old May 2, 2009 | 06:13 AM
Innes's Avatar
Huge list of some serious used race parts for sale
Contact:
Email -- James@IPGParts.com
Phone -- 407-324-4684
Check out the Race Parts here -- http://www.ipgparts.com/index.php?cc...66&act=viewCat
Please PM, Call or Email with questions and I can offer more detail on the parts that are lised available
-- Arias 84mm, B Series, High Compression Pistons (around 13.0:1) -- built with a 2 ring design for a maximum horsepower design , barely used, no rings, wrist pins or locks included -- ( http://www.ipgparts.com/race-parts-6...series-76.html ) -- $249
-- 95mm Hunter B Series Crankshaft, New, never used -- ( http://www.ipgparts.com/race-parts-6...series-79.html ) -- $999
-- Freshly sleeved Golden Eagle 86.5mm B18c Engine Block, bare with matching main caps, has pistons that the block is already bored/honed to that can be sold to the buyer if interested and the 95mm crankshaft that is being offered can be included with ACL bearings that are already spec'ed for install as well -- Block alone -- ( http://www.ipgparts.com/race-parts-6...m-bore-81.html ) -- $1000
-- GForce Honda B Series Dog Engagement Gearset (Dogbox), complete with case, final drive, 5th gear handcuff, etc (you just have to supply your own differential/spool) -- ( http://www.ipgparts.com/race-parts-6...g-box-287.html ) -- $3500
-- Ferrea Roller Rockers with Camshafts, Valve Springs, Retainers and Seats -- this is a complete setup ready to install in your cylinder head -- will work great in a naturally aspirated or turbocharged application -- ( http://www.ipgparts.com/race-parts-6...8c-b16-86.html ) -- $1700
-- Keizer 15x9, 4x114.3 Lug Pattern wheels with Hoosier 25x9x15 Slicks -- (http://www.ipgparts.com/race-parts-6...licks-288.html ) -- $649
-- Keizer 15x3.5, 4x100 Lug Pattern Wheels with Hoosier 25x4.5x15 Tires -- ( http://www.ipgparts.com/race-parts-6...tires-289.html ) -- $649
-- Ground Control Advance Design Coilovers for 92-95 Civic, 94-01 Integra -- great, very usable and easily customizable coilover set, currently setup for a drag application with 500 lb front springs and 1250 lb rear springs - ( http://www.ipgparts.com/race-parts-6...tegra-290.html ) -- $1150
-- Weldon 2025-A Fuel Pump -- used but in good working condition -- ( http://www.ipgparts.com/race-parts-6...-pump-291.html ) -- $539
-- 300+ Horsepower B Series Vtec Longblock - full list of specs ( http://www.ipgparts.com/race-parts-6...block-292.html ) -- $6900
-- ATI B Series Race Damper -- Part # 918470 --( http://www.ipgparts.com/race-parts-6...amper-293.html ) -- $285
-- Weldon Fuel Pressure Regulator -- Part # 2040-200-a-120 -- ( http://www.ipgparts.com/race-parts-6...lator-294.html ) -- $175
-- B Series Side Exit Race Header -- Made with Burns Stainless Parts -- ( http://www.ipgparts.com/race-parts-6...nless-295.html ) -- $649
-- Hogan Racing B16/ITR Intake Manifold with 80mm Accufab Throttle Body and Fuel Rail -- ( http://www.ipgparts.com/race-parts-6...-rail-296.html ) -- $899
Contact:
__________________________________________________ __________________________________________________ ______________________________
Used but in good usable condition Weld 13"x8" Magnum Import Drag Wheels with Mickey Thompson 24.5"x9"x13" ET Drag Slicks Mounted.
The Weld wheels feature a 5" Backspacing, are a 4x100 Lug Pattern and are already drilled and have rim screws installed as well.
The tires have seen better days. We aren't 100% sure the # of passes on the slicks but I would venture to guess at least 25+ by their condition.
One of the slicks also has a groove cut into it from what we would believe to be from the front of the car they were mounted on during braking after a 1/4 mile pass. The groove isn't cut very deep and that slick is still in usable condition but we wouldn't recommend using it for very long but you can surely get some passes out of it before you decide to swap it out for another one or a whole new pair of slicks.
This is a great chance to one of the best drag wheel setups at a fraction of the price of buying all the parts new.
$649 plus shipping
This is a great chance to get into a Drag Racing chassis at a fraction of the price of what it would cost to build.
This is a 1995 Honda Civic Chassis, all complete, not cut up at all and features some of the most popular drag racing parts on the market already installed on the chassis.
** This is Non-Rolling Chassis, no powertrain -- We can probably set the back up to roll out of here but we will have to put the front on a Dolley to get it out of the warehouse as there is no front suspension on the chassis currently **
Parts installed on this chassis include:
MB Fiberglass One Piece Front End
MB Fiberglass Doors
Lexan Windshield, Quarter Windows and Rear Hatch
MB Fiberglass Rear Hatch
5 Point Roll Bar
Kirkey Racing Seat with Simpson 5 Point Harness
Grant Steering Wheel
Custom Aluminum Dash
Autometer Tachometer
AUtometer Oil Pressure Gauge
Autometer Water Temperature Gauge
Autometer Volt Meter
Painless Wiring Switch Box
Safecraft Fire System
Battery Cutoff Switch
Hurst Line Lock
Brake Lines are all still intact
Pedal Assembly with Clutch and Brake reservoirs
Rear Trailing Arms
SPC Rear Camber Kit
Rear Disc Brakes
This car would cost at least double the asking price not even taking into account the paint job.
The chassis will make a great all motor car (as it was in its previousl life) or a Hot Rod style car with your turbocharged engine setup or there are a lot of other ways to just enjoy your very own Honda Drag Car.
$2900
Old May 2, 2009 | 06:45 AM
y.o. boosted eg's Avatar
EXEDY twin disc-3,000mil=$800 shipped
Custum comp.turbo 76mm turbo bb t4
.96 hotside 3.5 v-band outlit $1,500 shipped
redboost10's Avatar
sold
Old May 2, 2009 | 07:38 AM
Ej1ownzu's Avatar
2.)Percision 1000cc injectors 230 shipped.
4.)BW s372 standard cover. $950 shipped. +3% paypal.
Old May 2, 2009 | 09:40 AM
sho_tyme_psi's Avatar
Default Re: May WTB Sticky. please read rules
F/S spearco 1200hp water-to-air,lovefab B series manifold
Seller Chris
Location Connersville
Contact 765-748-0070
F/S
spearco 1200hp water-to-air intercooler $450
T4 forward facing manifold S O L D
Prices include shipping and paypal fees,Just need this stuff gone. : (
feel free to call or text.
Chris 765-748-0070
Thanks
Old May 2, 2009 | 09:57 AM
WillieWillieFast's Avatar
I made 500hp on 17lbs with a 81m block. This kit is capable of making 800hp + with high boost. Everything has less then 2000 miles on them and less then 8 times at the track. Kit includes: Inline pro T4 manifold with a Tial V60 (1 bar spring) with dump tube, Burg Warner S372 turbo (72m) with 4in down pipe and -10 oil return line and -4 feed line $2000.00 SHIPPED
OR WILL SALE Bulleye Power/Borg Warner S372 turbocharger, with extended tip technology, capable of 900+ horsepower. This turbo is the equivalent to the Garrett GT42R. Great turbo for all small to mid displacement 4/6 cylinder engines, or for twin turbo setups on V8 engines. With a maximum mass flow rate of 94lbs/min, the S372 is a high-boost and efficient turbo that can flow enough air to support 900+ wheel horsepower, yet still spools as fast as most similarly-sized ball-bearing units. By extending the ends of the compressor wheel, BorgWarner has effectively increased the pressure ratio, efficiency and flow of the entire compressor. This gives the S372 pressure ratios and efficiencies that can normally only be had with larger, slower spooling turbos. *Compressor Wheel Inducer - 71.8mm *Compressor Wheel Exducer - 101.9mm *Compressor Wheel Trim - 50 *Turbine Option - Inlet – T4 * exhaust housing A/R 1.00. Will come with fittings, feed and return line. Turbo has a 3in V-band instead of the 3.5in(makes it easier to fit in smaller engine bays like a CRX). $1100.00
Used Motec M4 with, data logging, lambda, and advanced functions unlocked. Comes with data cable, baro sensor, Honda B series distributor, o2 sensor and the motec Honda harness. For more info http://www.motec.com.au/m4/m4overview/ $2095.00 OBO
Magnaflow Regulator $120.00 SHIPPED
Mugen shift **** $75.00
CRX front upper control arms $140.00
Hasport motor mounts for a CRX with a B series motor with hydro tranny. Mounts come with solid and rubber inserts. $420.00
Old May 2, 2009 | 01:59 PM
93LSivic's Avatar
For sale:
AEM EMS 30-1000 box. Just came back from AEM for check up. Has been modded by AEM for a hall sensor setup and a 4th coil output to run direct fire ignition. Included is the 4th plug for the outputs along with pins and also including the serial cable. No software CD (download from AEM)
Price drop, $650!
FJO injector driver. This is the first generation model. Worked well, but have since decided to use a staged injector setup consisting of all saturated injectors so I have no need for it any longer.
$100
Pics available upon request.
Paypal or credit card accepted.
email: Dan@firststatemotorsports.com
Paypal: turbocivx@comcast.net
First State Motorsports
302-798-7000
Old May 2, 2009 | 03:56 PM
1qkfodo's Avatar
FS a complete 97 LS head and JG eldelbrock intake.
the head has had some minor port and polish work and it has Ferrea valves (stock diameter) and five angle valve job 1 year old, and crower springs and retainers also a year old. it also comes with a set of Brain Crower LS Turbo cams ( Cam Gears not included) about 6 months old, also LS ARP head studs and two LS valve covers, 1 is stock and the other is a Morsoe cover.
The intake has been bored and bleened for a 74mm throttle body. (throttle body not included)
we are asking $1500.00 for everything together as a package deal. buyer will pay shipping and paypal fee of 3%.
if you have any questions feel free to pm me or my brother ( oneqkfodo ) on here also.
Old May 2, 2009 | 09:17 PM
90sedan's Avatar
FS:
(4) NEW Hoosier A6 tires. (225/50ZR13)
(2) New Lenso VPD's gunmetal 13x7.5 4x100
The Tires new would cost ($188 each plus shipping/mounting/balancing)
All four tires were mounted on lenso's and literally have less than 1 mile on them. They were driven around the block to make sure everything fit/cleared correctly, so they are in brand new condition. I got them from a friend who decided to head in a different direction with his car.
This is the first set of tires mounted on the Lenso's as well.
Since i work at a dealership there is no issue with dismounting the tires for sale.
Price is OBO. Just keep in mind shipping costs.
I would be interested in trading for a set of white lenso's though.
Non of the rims/tires have any damage, there's a little bit of tire mounting paste on the lip in a couple spots that may look like curbage.
Old May 3, 2009 | 07:16 AM
RPRacing's Avatar
FS: ATI Damper. Used for about 2 months. but was drag car that sat in a trailer for most of that time.
part number is 918471
$325 shipped through payapl (i'll cover all applicable charges)
-Francisco
Old May 3, 2009 | 09:14 AM
lwct100's Avatar
B series manifold run in my ef, ran a T4 72gst on it. I designed this to run minamum amount of piping ( to fit in ef cramped chassie) Sits turbo at a angle so the down pipe is really short . Set up for a 50mm JGS wastegate.The maifiold is all stainless. Made over 800 hp with this manifold.$450.00 shipped
Old May 3, 2009 | 09:19 AM
jpenman50's Avatar
Paypal fees and shipping is additional!!!!!!!!!
- 90 mm accufab throttle body- $150.00
-Crower 402 all motor cams $250.00
-FAL single fan shroud and motor, no blade (blue)- $30.00
-2 piece aluminum catch pan (NHRA Legal) $50.00
-Rear t bracket for b series $30.00
-Front suspension froks (set) $20.00
-Edlebrock fuel rail $50.00
-JDM 1 piece del sol headlights $200.00
-MSD pn6562 Boost retard controller $100.00
-MSD pn8912 Tach adapter (2) $25.00
-Nippen denso 550 cc side feed injectors, new (6) $25.00 ea.
-GM boost controller siliniod with wire $20.00
-Tech edge wide band with ntk sensor and display (2 units) $180.00 ea
-Autometer new egt bungs (2)- $10.00 ea.
-RC 440 cc injectors (6)- $200.00
-GSR oil scrapper (new oem honda)- $30.00
-GSR half shaft- $30.00
-Stock radiator overflow bottle, spark plug cover (black)- $10.00
-Turbo xs 4 stage boost controller- $125.00
-Front radiator 70 lbs balast bar- $35.00
-2 Endyne 14:1 compression pistons- $50.00
-AEBS Sleeved b16 block (last bored at 84.5 mm) - $500.00
-ARP used head studs- $40.00
-B16 ported head with cam caps (head only no lma, or valves) $200.00
-LS used stock shortblock with steel moroso oil pan- $250.00
-Aluminum radiator with oem fan- $100.00
-Precision sc61 s cover p trim ballbearing turbo (only 100 miles on it from my street car) - $750.00
-Precision intercooler (600 hp)- $300.00
-Precision intercooler end tanks (3) - $50.00
-FAL single blue fan shroud and motor (no blade)- $30.00
-Progress dampner struts (front)- $140.00
- 99 si 3 gauge piilar (gray)- $20.00
-Pro Drive Hubs (for small bearing)- $50.00
-obd1 to obd2a boomslang jumper harness- $ 50.00
-AEM 5 bar map sensor- $ 85.00
-T4 ram horn turbo manifold with hpc black coating- $250.00
-Jegs fuel sample valve- 25.00
- 2jzgte is300, gs300 turbo kit- $2000.00
Pics are availble upon request... All pricing does not include paypal fees of shipping .. thanks for looking.
Old May 3, 2009 | 12:10 PM
building boost's Avatar
sold.
Old May 3, 2009 | 11:47 PM
94WhtLytng's Avatar
New in box Strange Engineering Honda shocks. Bought for a project and never used. Available with or without 650lb springs. $550 for shocks, $600 with springs + shipping.
Old May 4, 2009 | 09:54 AM
Whitfield Inc.'s Avatar
Trying to unload and rebuild for 2010 ---
Email any serious questions about sale of trades cars are all ready to ship to JASON@RAGEIMPORTS.com
parts -
old school DFI first gen, used on old race cars pump out put not working just put it on a switch ---- Gen 7 DFI with ign box used before we went Motec on the car ---- FULLRACE H22 top mount for t4 w/twin vband wastgate used for fitting and went back to B series now so we dont need it
cars / trailers
Sport Cobalt ( asking 20, 30 with spares ) - Sport Ek ( asking 10,500 ) - Street Eg ( asking 8500 ) - SuperCharged Aveo ( asking 20 ) - Hot Rod rex ( parting out so email ) - Xtrac - GoldRush 40 foot trailer ( asking 30k but taking offers new trailer is built and wd need to move this 1 first Gold Rush said this is worth approx 45 now and would cost 75 to build today )
Jason@RageImports.com for any real serious buyers thank you for looking.
Old May 4, 2009 | 10:31 AM
Themouse's Avatar
WTT: BW S366 BNIB for BW S372 or S368
Its Thermal coated and powered coated
Looking for $1100 shipped
Old May 4, 2009 | 08:21 PM
ExospeedAMcrx's Avatar
Got stuff laying around here for awhile. No need for them. Rather have someone else use them.
B18A1 Open Deck Sleeved 84mm $Sold
New. Just needs final hone for your pistons and recommended line bore.
Includes Main Caps
B18A1 Golden Eagle Sleeved 84mm with O-Rings $Sold
Recommended final hone and line bore.
Includes Main Caps
B18A1 Open Deck Sleeved 84.5mm+ $650.00
Last used as 84.5mm, Recommended 85mm+
Just fresh bore/hone needed and youre good to go!
Includes Main Caps.
H22 Darton MID Sleeved 87mm $Sold
NEW! Fresh and so Clean!
87mm, ready to go! Just need final hone for your pistons.
DARTON MID!
No Core Exchange needed.
Includes Main Girdle.
D16A6 Open Deck Sleeved 78mm $600.00
Arias Custom D16A6 78mm 13:1 $450.00
(With Eagle Rods)
Recommend getting new rods or at least 2 rods.
1 missing rod cap and 1 missing rod bolt
Custom H22 Turbo Pistons : a deal at $580.00!
87.5mm, 10:1
Upgraded Wrist Pins
Complete Piston Ring Set
Top and skirt coating
New for all this at $850.00
Custom B-series Pistons 84mm, Hard Anodized with Buttons $650.00
84mm, 10.5:1
Upgraded Wrist Pins
Complete Ring set
Custom Hard Anodized! Exceeds wear characteristics of Ceramic coatings
Aluminum Pin buttons! No pin clips! NO worries of clips backing out.
This set is over $900 for a custom order.
Also added: but no pics yet avail.
B18B Darton MID sleeved 81mm $1150.00
NEW! Freshly Sleeved and installed.
With main caps
Just need final hone for your pistons and youre good to go.
B18A Darton MID Sleeved 85mm+ $950.00
Was used for our backup motor. Planned to reuse it but never had the chance to rebuild motor.
Was last used as 84.5mm. Recommended for use as 85mm+
Just needs a new bore and hone and youre good to go.
With Main Caps.
K24 Open Deck Sleeved 87mm $1490.00
New!
Bore and Hone matched to Wiseco Set
Includes main girdle but missing main bolts.
Wiseco 87mm 8.8:1 for use with K20 head
Brand New Set
Wrist pins incl.
No Rings
*(Both sold as package)
- Slight dent on corner of block and main girdle.
B20B1 Block with Main caps $225
Fresh and so clean!
for 84.5mm
New Bore and Honed block
Bare, no crank or oil pan or internals.
MB Fiberglass Dash: Universal $140.00
Will fit in most common Honda used race cars.
May require trimming on certain areas to fit around cages, etc.
Bogart Drag-On Fly Star 14x8, 4x100 $380
with M/T 20x8x14(recommended to change)
Rare! Custom Made set.
Old May 4, 2009 | 08:34 PM
f@sth@tch89's Avatar
Skunk2 GSR Manifold $125
RC 370 cc Injectors $200
BDL Fuel Rail $100
Old May 5, 2009 | 08:46 AM
FRernesto's Avatar
Used 65mm Edelbrock throttle body 165.00
**F/S GT35R used with either a twin scroll 1.06ar housing HPC'd black 1600 degree. Or standard .82 ar housing none HPC'd. This turbo has only been used for track use and does not smoke at all. The HPC on the 1.06ar housing is in perfect condition along with the whole turbo. Make offers on either!!! Must Go!!!!
F/S Used Precision Turbo PT74 this is a used turbo 74mm with a turbin housing of .81ar. The turbo has been lightly used and is in good condition. Inquire about price... Thanks!!
Last edited by FRernesto; May 29, 2009 at 03:10 PM. Reason: Inline pro manifold sold.
Old May 5, 2009 | 08:49 AM
anykind's Avatar
New User
for sale : Speed Pro engine management : Set up for H22
comes with harness,software disk,O2 sensor,H22 distributor,NGK wires,usb cable
MSD Digital 7 ignition box,MSD HVC Pro coil.Set up came from Drag Cartel Drag CRX
I can send pics via blackberry phone.$1000 for everything. 808-864-2655
Old May 5, 2009 | 11:09 AM
ctr-ek's Avatar
ok i got a 97 legit b20 block with 84.5 bore, 12:5:1 Cp pistons, G.E. rods, acl race bearings, new ls crank, chimmed type r oil pump, all gaskets r new from dealer, oem resurfaced flywheel, G.E. headstuds, G.E. vtec oil kit, gates racing timing belt and new water pump. block has about 1000 miles on it asking 1800obo
vin:JHLRD18631S027003 b20z: 4047055
-4 fogger system up for sale comes with everything u need to put the system on including jets (100shot) i had this has a backup but i no longer need it im asking for 500firm
-kevlar whale ***** brand new asking 200
-96 jdm type r cams while about 10,000miles on them asking 300
-also have a brand new 65mm edelbrock t/b for sale asking 300
!!!!!!!!!DO NOT WASTE MY TIME LOWBALLIN!!!!!!!!!!!
im located in New Jersey serious buyers only!!! pics will be up soon shipping and paypal fee are NOT included.
Old May 5, 2009 | 01:02 PM
atomikcoupe95's Avatar
I have a built gsr long block for sale and some parts.
GSR HEAD has skunk 2 pro series springs and retainers and super tech valves and new valve seals and guides stock cams- for$1000
4 bar hondata map sensor- for$50
ARP head bolt- for$50
Old May 5, 2009 | 01:17 PM
b20vtech's Avatar
FS: under 10 miles Tilton twin disc clutch kit for b-series hydro tans 650+ shipping, my lost ur gain
cost me 1200 new
