Honda S2000 Honda S2000
17x8 17x9 +33 ?
Old May 1, 2009 | 11:23 PM
accord03coupe's Avatar
Icon2 17x8 17x9 +33 ?
i come across this set of wheel deal.
i know that i have to roll fender and negative camber.
how much camber should i do if drop on 1 inch.
anyone have same set up and have some pic?
thank!
Old May 2, 2009 | 12:20 AM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
Default Re: 17x8 17x9 +33 ?
you should be fine with a 1" drop for regular driving. I just put on some 17x8 +45 17x9 +45 with the eibach pro kit (1") and I don't rub. Just be careful with suspension travel while spirited drives. Negative camber and rolling your fender is definstely a good idea. I know I'm gonna consider it.
Old May 2, 2009 | 03:16 AM
v_I_etn_AM_ese's Avatar
New User
nice
Old May 2, 2009 | 11:14 PM
midwesta's Avatar
Honestly too low of an offset if you aren't gonna run coilovers, the car will just look weird.
Old May 3, 2009 | 07:00 PM
Black S2K's Avatar
^ meaning you cant go low enough to tuck with -54548 camber and your car will just look like a monster truck
Old May 3, 2009 | 08:15 PM
How low shoud I go if I want to make it look right?
I really like the rims
Old May 3, 2009 | 08:29 PM
midwesta's Avatar
I wouldn't try to run a low offset without coilovers, you will run into a lot of rubbing problems because springs have too low a of a spring rate and too much travel.
Old May 10, 2009 | 10:28 PM
meso_S2K's Avatar
^+1
Old May 11, 2009 | 11:52 AM
jdm_dc_fan's Avatar
45 on a nine inch wheel sits pretty flush with the fenders cant speak for 33 though.
Old May 11, 2009 | 03:34 PM
Mar48's Avatar
You will for sure need to run a lot of camber and will need to roll all four fenders unless you plan to run stretched tires on there.
Btw, what wheels are those? Don't know if I have ever seen them
Old May 11, 2009 | 09:36 PM
anyone got picture to show how much it stick out on the car?
thank!
Old May 14, 2009 | 01:14 AM
illdiealonlyazn's Avatar
i hope you realize that youre gonna have to roll and pull your fenders to fit that. a drop on a +44 will already require rolled fenders. Any less then that and youre gonna have to go to stretched tires and camber too + pulled fenders to fit it.
Old May 14, 2009 | 07:52 PM
jakobe06's Avatar
Ive got +25 fronts and +27 rears,17x8 & 17x9,with a 2 and a half inch drop,and my front fenders are rolled,and i grinded the rear lips perfectly to the edge and painted over where i grinded to prevent rust,with hardly any camber adjustment at all and i dont rub at all!
Old May 14, 2009 | 08:03 PM
esoterEK..'s Avatar
got pics?
Old May 14, 2009 | 08:17 PM
jakobe06's Avatar
17x8 +25,17x9 +27
hillbillycivic
Suspension & Brakes
Jul 9, 2013 04:10 PM
joelmatt89
Oct 7, 2009 01:55 PM
tmramsburg
Oct 22, 2005 03:00 PM
Tyronn24
Suspension & Brakes
Jun 7, 2005 11:10 AM
