??rack&pinion how to remove??
93 civic h/b rack is loose how do i get it out from under car ? pulled left tie rod and droped exaust does not seem like there is enough room to get it out. does eney one know if i can take it apart or if i can take the little shaft off that connects the stering wheel if so how? in lamens terms
pull the tie rods, take the bolt at the end of the steering column out, 4 bolts that hold it to the k-member, then feed it towards the pass. side until u can pull the drier side out.
Hcivic88
48
Jun 5, 2017 03:07 PM
acmoc
May 23, 2013 03:32 PM
Jaydeep
Honda Civic (2001 - 2005)
Aug 29, 2012 09:45 PM
*Boostwerks*
10
Oct 6, 2005 09:12 AM
