Suspension & Brakes Theory, alignment, spring rates....
How long does it take for springs to settle?
Old May 1, 2009 | 04:22 PM
jrthestar's Avatar
Default How long does it take for springs to settle?
I put some agx struts with h&r race springs and i wanna no how long it takes for the springs to fully settle in? Their on my 94 ls
Old May 2, 2009 | 09:14 AM
jrthestar's Avatar
Default Re: How long does it take for springs to settle?
bumppppppppppp
Old May 2, 2009 | 10:44 AM
gosu08's Avatar
they take about 500 miles. that was with me...hope that helps
Old May 3, 2009 | 05:15 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Springs don't settle. Bushings tear. You should always make sure you loosen all the control arm bolts that go through a bushing and tighten them with the car at ride height. If you don't, the bushings will be preloaded and eventually tear, which is what most people mistake for springs settling.
Old May 4, 2009 | 06:37 PM
jrthestar's Avatar
I just want to know because my passenger front side is low and the rears a bit higher and then my driver side its the opposite the front is higher then the rear so i just wanna make sure they settle in
Old May 4, 2009 | 06:51 PM
TunerN00b's Avatar
As has been already posted, springs don't settle.
Failure to correctly follow the manual and clock the bushings is frequently mistaken for "springs settling".
Old May 4, 2009 | 06:56 PM
jrthestar's Avatar
How do you clock them? I just wanna have my dam ride at even height front same height and like wise for the rear help is appreciated guys thanks
GoLowDrew
Suspension & Brakes
Mar 27, 2011 04:58 PM
asianalbutt
Oct 23, 2005 11:38 PM
gofastgsr
Mar 23, 2004 09:50 AM
LillDragun
Mar 25, 2003 11:35 AM
