bad wiring or am i just doing the wrong thing
Old May 1, 2009 | 12:56 PM
hitman123's Avatar
Default bad wiring or am i just doing the wrong thing
ok i just bought a crx. my left turn signal in the front does not work, but my day lights work. i got a wiring diagram and followed the green/blue wire down and i found that it was disconnected. I connected it straight to one of the lights and the blinker turned on and was blinking but so was all my other lights. then i turned on my lights and the blinker just stopped and in the dash the arrow was just solid it wasnt blinking. please can anyone help me
Old May 1, 2009 | 12:58 PM
hitman123's Avatar
Default Re: bad wiring or am i just doing the wrong thing
i need some help please someone help me
Old May 1, 2009 | 01:10 PM
hitman123's Avatar
bump this i need an answer or at least a clue
Old May 1, 2009 | 01:12 PM
hitman123's Avatar
anyone have a clue?
Old May 1, 2009 | 01:19 PM
hitman123's Avatar
another bump just because i need an answer really fast
Old May 1, 2009 | 01:27 PM
boostedmonkey's Avatar
Where exactly is the blue/green wire disconnected from?
What year is your CRX, also?
Old May 1, 2009 | 01:31 PM
hitman123's Avatar
it was down all the way by the end of the harness in the front of the car.
Old May 1, 2009 | 01:39 PM
hitman123's Avatar
ohh its an 89si the green/blue wire is the one for the turn signal and hazard lights well according to the diagram i have
Old May 1, 2009 | 01:50 PM
Is it a bare wire like it got ripped out of something? What did you hook it up to? Headlight wiring? Possible you grounded something out when you hooked it up to something. Let me look at our wiring diags here at work. I work at a Honda dealership. Let me see what i can come up with.
Old May 1, 2009 | 02:01 PM
hitman123's Avatar
it looked like it was just cut. i hooked it up to the bumper light, i just basically extended the wire just to try it. I should also bring this up it has one of those fast blinkers the other side is fast also but it works fine could it be something with that because when i hooked it up straight to the light the blinker was blinking at its regular pace.
Old May 1, 2009 | 02:30 PM
domokun!!!'s Avatar
wow bumpzilla over here, youll get an answer you just need to have patience.
Old May 1, 2009 | 03:11 PM
Okay. Your Green/Blue wire goes back from your left front turn signal bulb connector, to a jumper connector. It continues on back to the turn signal switch, still with a green/blue wire. Take a look at your connector for your left front turn signal, and locate the green/blue wire. Try to chase it back. If it's been disconnected or cut right off of the turn signal bulb connector, just butt connector it back together and it should work. If not, then your problem goes deeper. We'll get it figured out.
Old May 1, 2009 | 03:43 PM
hitman123's Avatar
thanx boostedmonkey im gonna do so more research before i take this to a shop. i think the harness has been hacked up or could it be because it has a jdm front end i chased the wiring all the way down and i think i found the connections to the corner light and the bumper light just hanging there. so i traced the connections of the lights as they are now and they are all just connected to a red/black wire so this might be worst than what i originally had thought.
Old May 1, 2009 | 03:57 PM
Red/black goes to your left front marker light.
honda_coupe
Apr 11, 2010 08:10 AM
EK Josh
Jul 26, 2005 09:38 AM
jDm t3g
Apr 6, 2003 06:37 PM
HatchBox
15
Dec 6, 2002 06:50 PM
