engine vibration
Has anyone experienced a vibration between 2200-2600 RPM's? It happens when im idleing and rev up to that rpm. I can feel it in the steering wheel and the pedels. Thanks
EDIT: Also iv been haveing this whineing noise coming from the right side of the motor. It sounds like a pully is going bad or something. I notice it alot more at lower rpms. I have 55k on my si.
Honestly, I think the vibration you may be feeling is the throttle body finally responding to your foot's input. The DBW causes such a lag that the car does not immediately respond when you rev it. Maybe that range is where the electronics finally realize you are putting the hammer down. IDK just spit-balling.
Do you mean the right side of the engine from inside the car? Because all of the pullies are on the left side of the engine (when under the hood facing the windshield). It is your PCV valve and more than likely normal. Had the same "problem".
PatrickGSR94
Transmission & Drivetrain
Mar 31, 2011 06:56 AM
