removing power steering..
Old May 1, 2009 | 08:09 AM
itsLOUiSduh's Avatar
Default removing power steering..
If you dont lube the rack and pinion will that make your car screech whenever your driving?? I forgot to plug my lines so the power steering fluid leaked all over the place but i wasnt sure if thats what is making the noise. It sounds like my brake pads are riding on the rotors because the noise is constant not only when i turn.. any suggestions??
Old May 1, 2009 | 08:54 AM
medorihb's Avatar
Default Re: removing power steering..
well check your pads. when was the last time you did a brake job.
Old May 1, 2009 | 07:39 PM
i just did them recently. all four. any other suggestions anybody?
Old May 1, 2009 | 08:28 PM
Kazan's Avatar
you can try and remove the power steering belt, that will stop the pump from actually turning and making noise, I think...
Old May 1, 2009 | 09:08 PM
JarvisW's Avatar
Sol to Sol
Yeah, thats probably it. Also there are a few threads on how to loop your system so it dosent ruin your rack-n-peanut.
Just do a search on power to manual, and you should find several.
jayjazmin
Honda CR-V & Element
Aug 5, 2014 09:20 AM
sky9
Feb 25, 2011 02:40 PM
94sirintegraGP
Sep 20, 2008 12:23 PM
slowww b18b1
Dec 1, 2003 07:56 PM
94TealGSR
Dec 15, 2002 10:30 AM
