Type R steering wheel on ef
Old May 1, 2009 | 07:07 AM
EF9Sirjdm14's Avatar
Default Type R steering wheel on ef
hey wats up i was wondering if i can up a type R steering wheel on my ef and is it possible bto make it detachable ?????? anybody have any pics thanks
Old May 1, 2009 | 03:08 PM
hushypushy's Avatar
Default Re: Type R steering wheel on ef
Which Type R are you talking about? There are a few out there. The EK9 and EP3 wheel will definitely not fit, and I'm not really sure about the NSX-R but I doubt it fits. The DC5, Accord, and the newer Civics will not work either.
But the DC2 ITR wheel will, this one:
The EF and DC steering hubs are not the same, but are slightly different--enough that you can run EG/DC hubs on an EF. I have a Momo hub on my EF that's actually for an EG, and it works fine, it's just ever so slightly loose.
AFAIK you can't make it detachable, because you'd have to attach the wheel to a QR, and I think the ITR wheel has the hub built in to it:
If you can take the hub off the wheel, then you could hook it to a QR. However, I don't know if that's possible. I do know that you can use the (for example) Honda Access steering wheels to a QR because they have a standard 6 bolt pattern that will attach to any hub. That's what I'm using in my EF.
Old May 1, 2009 | 07:31 PM
yes that is the steering wheel i would like to put on the (DC2 ITR) i really like that that steering wheel a lot especially on a EF i think its a different look, almost everyone i know goes with aftermarket QR but i jus wanna keep it jdm u know...
Old May 1, 2009 | 07:52 PM
hushypushy's Avatar
Well if you like that wheel, check out some of Momo's other wheels, like the Tuner, Corse, Monte Carlo, etc etc. That would be really easy to hook up to any hub/QR you want, not to mention you can get a proper DA/EF hub that actually fits and will let you use a horn
Old May 1, 2009 | 09:45 PM
DAEF91's Avatar
Thats actually the steering wheel I have in my 91 si....like it very well. actually I am thinking about putting in a DA dash as well as my front end. I think it will go quite nice. Ill post pics whenever I have it all done.
Old May 7, 2009 | 02:40 PM
SIR HATCH's Avatar
i know some one that can make it detachable!! let me know if your still interested
Old May 7, 2009 | 03:58 PM
Turbo Dan's Avatar
check out my install, by far the cleanest and most proper way to install imo
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-install-itr-wheel-my-way-2444253/
Old May 7, 2009 | 07:31 PM
hushypushy's Avatar
https://honda-tech.com/forums/showthread.php?t=2444253
not "by far", but I still agree with you
89ED
Jan 20, 2019 09:28 PM
89ED
Jan 20, 2019 08:24 PM
stevieturbos
Jul 14, 2010 08:45 PM
Scotland:EF3
Feb 19, 2007 11:02 PM
