Suspension & Brakes Theory, alignment, spring rates....
Sway bars/lca
Old May 1, 2009 | 12:53 AM
SlowEJ8's Avatar
Default Sway bars/lca
Will i need to get an alignment when i get lca, and sway bars?
Also do i need to get alignment everytime i change the height of my car?
Old May 1, 2009 | 01:16 AM
xd69's Avatar
Default Re: Sway bars/lca
Only if your LCA was bent or if the LCA you are replacing it with is not the same size.
Yes an alignment is needed every time you change the ride height of the car unless you can afford new tires every couple of months
hatch is best
Nov 9, 2006 11:16 AM
egb18c5
Dec 23, 2005 11:31 PM
higgunscrx
May 16, 2005 04:07 AM
Si Arn
49
May 3, 2004 09:59 PM
