DA with 2000 LS Intake Manifold and Throttle Body
Old Apr 30, 2009 | 09:30 PM
islandauto's Avatar
Default DA with 2000 LS Intake Manifold and Throttle Body
Ok, here's a little background
I have a 90-93 Integra original motor and it came with a 2000 LS Intake Manifold and Throttle Body.
Problem I'm having is that it starts up, idles for a second and then shoots up in RPMS to 4000. Thought it was the intake manifold gasket, changed it and still the same thing. Checked for vacuum leaks, and I'm stumped. Not sure about these cars so Maybe there's some extra steps I need to take to make this manifold and throttle body work on this motor and would appreciate any help I can get on this subject. Also where can I locate the check engine light connector. Any help is appreciated.
Please if you have something negative to say, keep it to yourself, thanks.
Old May 1, 2009 | 02:41 AM
MD426's Avatar
Default Re: DA with 2000 LS Intake Manifold and Throttle Body
The CEL is under the passenger side dash, it's the 2 pin connector not the 3 pin one. The only thing I can think of right now is maybe the TPS is adjusted wrong.
Old May 1, 2009 | 03:19 AM
Targa250R's Avatar
be professional
Easy, fast, painless solution: install the correct B18A1 intake manifold and throttle body. They're cheap and plentiful. In fact, you could probably find one for free, or as a trade for your OBD-2b B18B1 manifold.
Old May 1, 2009 | 03:55 AM
MD426's Avatar
He probably bought it for a reason, B18B Intake Mani have better air flow.
Old May 2, 2009 | 10:48 AM
islandauto's Avatar
thanks for the positive answers and your help. the car came with the newer style intake mani, was just seeing if it could work. I know it has something to do with the throttle body, but i'm not sure
mini-cRx
Feb 4, 2004 06:58 PM
Duck Sauce
Nov 28, 2001 08:47 AM
