stereo code help
Old Apr 30, 2009 | 06:17 PM
sohckid00's Avatar
Default stereo code help
so the issue is that i have a 04 rsx base model that i just bought. it has the code screen on since i have bought it. i went to a local acura dealer to get the code but it did not work.
the code that i recieved from the dealer was 31211. which did not work
- any one has any diffrent codes
- anyother options or ideas that you have or have done that have worked for you
- i am looking to keep this stock radio any feed back would be appreciated.
Old Apr 30, 2009 | 07:18 PM
DaveSi677's Avatar
Default Re: stereo code help
if you search it has been covered before plus with a step by step on what to do! But if the code doesn't work its because thye gave you the wrong one so I would go back and tell them that its the wrong one!
Old Apr 30, 2009 | 07:53 PM
gilbertdominguez's Avatar
New User
how can I get a code for a radio, because I disconnected the battery.
Old Apr 30, 2009 | 08:27 PM
prejdmlude's Avatar
From what i know when they receive the car from the manufacture the guys who clean them are suppose to install it on the inside of the glove box. if not it should be in your owners manual.
Old Apr 30, 2009 | 08:45 PM
sohckid00's Avatar
thanx davesi677 i was able to get the help i needed on a prev tread here this should help others with similar prop also thanx to k20tuner
https://honda-tech.com/forums/showth...ght=rsx+stereo
Old May 1, 2009 | 12:39 PM
DaveSi677's Avatar
its also cause I had the same problem and I posted a step by step on what to do to get your code... and I was to tired to search for it last night lol
Old May 1, 2009 | 10:06 PM
Dallask20's Avatar
if you open up the glove box there should be a sticker on the inner side closest to the HU that has a set of numbers which is the code to unlock the HU.
Old May 2, 2009 | 05:00 PM
sohckid00's Avatar
mine actually did not have the code placed anywhere on the car. and fyi when your pulling the code by useing the 1and 6 button method make sure to write down the code in the order that it apears first and second this is what messed me up now i got bump! and love it! :D thanx ofcourse to tarmacjunkie who helped me with this issue
Old May 2, 2009 | 08:35 PM
danielfleenor's Avatar
acura.com thats how i fixed mine
Old May 5, 2009 | 05:12 AM
smokinrice's Avatar
New User
I would say it has been replaced at one time and doesnt match the vin to your car.Iam dealing with same thing,It may take removing the radio and getting the service number off of it,then getting the right code.Ill know more today...
Old May 5, 2009 | 05:46 AM
DaveSi677's Avatar
u don't need to remove the radio to get the numbers for it... just follow the step by step it shows you how to get with out breaking your head...
Old May 5, 2009 | 05:48 AM
DaveSi677's Avatar
Ok here I'll post it again so you all can see how to...
All you have to do to get the radio security code is to turn off the radio, press and hold preset buttons 1 and 6 at the same time, then turn on the radio while you hold 1 and 6. The display will alternately flash two sets of numbers - a "Uxxxx" and a "Lyyyy." Remove the U and the L and put them together, and you get "xxxxyyyy" which is your radio serial number. Take this number along with proof of ownership and identification to your local dealership, and they can look up the security code for you through the Honda Interactive Network.
Old May 6, 2009 | 06:25 AM
sidious141's Avatar
Most easy way: Go here https://radio-navicode.honda.com/
Or call customer service, they give it to you FREE. Screw dealing with a dealership
Old May 9, 2009 | 06:02 AM
smokinrice's Avatar
New User
Thx for the advice on the interactive web site,2 diff.dealers and 2 diff.radio codes,got the right one from the website.Very Nice.
chinolopez
Jan 22, 2009 08:50 AM
mrsnj20
Sep 5, 2007 03:35 PM
moldy34
Apr 9, 2007 05:16 PM
manyakiexpi
Honda Civic (2006 - 2015)
28
Mar 5, 2007 11:24 AM
crx_ef8
Acura TL, RL & ZDX
Oct 3, 2003 09:03 AM
