Honda S2000 Honda S2000
Is it safe to Run Axle Spacers?
Old Apr 30, 2009 | 03:02 PM
ekhatchling's Avatar
Default Is it safe to Run Axle Spacers?
Just bought an 01 S2000. Previous owner had it slammed with axle spacers. I plan on putting back the stock springs but want to leave the spacers. Is it safe to run spacers on stock suspension?
Old Apr 30, 2009 | 07:55 PM
bky's Avatar
bky
Default Re: Is it safe to Run Axle Spacers?
Should be fine.
Old May 1, 2009 | 04:55 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
you dont need them on stock suspension...
Old May 5, 2009 | 01:05 PM
Srr's Avatar
Srr
yea u dont need them...sell them to me
Old May 5, 2009 | 03:01 PM
Black S2K's Avatar
keep it slammed duh
Old May 6, 2009 | 09:53 AM
negcamber's Avatar
Depending on how many miles the car was driven with it lowered, you may get a vibration on acceleration if you leave them in.
If you go back to stock height and you get the vibration, just remove the spacers and you should be good.
Old May 6, 2009 | 11:52 AM
White Smoke's Avatar
i my honda
Global Mod
Remove the spacers if you are going to rock the car at stock height.
Old May 10, 2009 | 11:06 PM
meso_S2K's Avatar
slaaammmmmed looks sick keep it!
Old May 12, 2009 | 10:16 AM
Thanks all for the advice. I've put it back to stock with spacers on and so far no vibrations. Couldnt leave it slammed cause my driveway is too steep. Had to go get a couple of 2x10s to use as ramps. Will get coilovers in the future and drop it 0.75-1in (that's all i can afford) instead of the 2in+ drop from before. Stock sucks! I can put four fingers in the wheel well!
Old May 12, 2009 | 10:27 AM
Mishimoto's Avatar
I think it's time to move to a new house! Haha.
Old May 13, 2009 | 12:01 PM
s2kdre's Avatar
U'll be good. AP2 Hubs are spaced out 5mm anyways
Old May 15, 2009 | 06:14 AM
negcamber's Avatar
That doesn't make sense...
The distance from flange to flange is the same on the ap1 & ap2 diff...and the axles are the same part number for both. If the hub were spaced 5mm out, the axle nut wouldn't have enough threads on the spline to grab.
Old May 18, 2009 | 12:50 PM
SpeedWorksRacing's Avatar
Neggy I have heard that too.
I have yet to prove it but I think it was Billman that told me to put ap2 axles in the car.
Old May 18, 2009 | 03:06 PM
negcamber's Avatar
Hey Speedy...
Strange...cuz it was Billman that did all the measuring when we were trying to figure out if the spacers did anything for an s2k.
You can prove it to yourself on the axles though...look em up...same Honda part number means same exact part.
Big Rhag
Apr 27, 2014 05:32 PM
vlang29
Apr 28, 2008 03:29 PM
ludeR917
Apr 10, 2004 12:35 PM
Tomservo
Feb 12, 2004 06:19 AM
JDM97R
Apr 25, 2003 09:15 AM
