Another rear bearing question......
Quick question. My 88 CRX has a swapped rear trailing arm from a 92 Civic Si (with ABS). Obviously I don't have ABS. I am guessing I can just use a rear assembly for a regular disc set up, or should I again buy the ABS assembly. I would think the only difference is the "sprocket" on the assembly for the ABS.
thanks
thanks
