Ignition switch does nothing - I know this is something simple...
Old Apr 30, 2009 | 11:04 AM
FBS's Avatar
FBS
Default Ignition switch does nothing - I know this is something simple...
I got in my car the other day to drive home from my uni. Turned the key and nothing whatsoever happened. No accessories, no fuel pump, no starter, nothing. First thing I thought was a dead battery, but my horn, high beams, brake lights, and everything else I can use without the key in the ignition works fine.
My next thought was the ignition switch I replaced a few months ago... Position 2 quit working so the car wouldn't stay running. I thought a complete failure would be odd, but I pulled it anyway and ran all the continuity checks. It's fine.
I'm no expert mechanic, and between school and work I've been too busy to sit down and test a bunch of wires. While thumbing through my manual, though, one of the wiring diagrams seemed to show a fuse between the battery and the ignition switch. Seems like the likely culprit.
The problem is I don't know where this is located. It's not on the fuse panels in the engine bay or under the dash. Could it be a relay problem? I've never had to deal with those so they're still somewhat of a mystery...
I know this is something simple and I'm going to feel really dumb when I get it fixed. D:
treal512
Feb 20, 2015 06:50 PM
carnot
Jul 9, 2012 05:28 AM
turbo-crx
Jan 22, 2009 06:46 AM
fcfromhell420
Sep 22, 2007 10:47 AM
GhostBB6
Jan 13, 2006 04:47 AM
