DOHC ZC in 91 EF Si
Old Apr 30, 2009 | 12:26 AM
billyanderson's Avatar
Default DOHC ZC in 91 EF Si
Engine turns,
89 PG7 ecu,
Everything wired right (maybe)
New Dizzy.
Replaced C.A.S (cam angle sensor) out of 89 Integra
triple checked all grounds
new battery
and it's getting fuel
Running on stock Ignition Coil till it get's
No Spark.
Using SI Wire Harness modded for CAS for DOHC ZC.
Just no spark as far as i know.
would the cam angle sensor wired backwards keep the engine from sparking?
any help would be greatly appreciated.
Old Apr 30, 2009 | 12:49 AM
likwid2u's Avatar
Default Re: DOHC ZC in 91 EF Si
try flipping the two white wires..... its a common mistake that most people do on zc's
Old Apr 30, 2009 | 12:53 AM
i have read about that before, where are these 2 white wires, i havn't seen them i have looked
Old Apr 30, 2009 | 10:11 AM
likwid2u's Avatar
on the distributor plug
Old Apr 30, 2009 | 10:47 AM
ok great. going to check it out now. thanks
Old May 2, 2009 | 04:14 PM
Turns out the person that changed the dizzy plug for us screwed it all up. car runs great, they had the 2 white wires backwards, and the only wire that was right was the orange.
thanks
Old May 2, 2009 | 10:21 PM
likwid2u's Avatar
my crx sat for months because of those wires,
Old May 2, 2009 | 11:11 PM
it's been 7 years for many different reasons.
GameBoyeas
Jun 5, 2017 05:25 AM
stickman78114
Feb 21, 2010 09:37 AM
DAGS-R
24
Apr 7, 2005 01:19 AM
cr-x si
Apr 8, 2003 12:42 PM
J98EX
Mar 11, 2003 10:29 AM
