Type S
car is 02
brought 04 engine.
When start the engine warm up in 15 sec.
Engine code p0335 and p0505
the engine is bouncing up and down between 2k adn 1100 while idling....
any Help would be greatful.
brought 04 engine.
Well P0335 means you are having crankshaft position failure malfunction. Check the sensor make sure it's still plugged in. Also pull it out (just one bolt holding it in) and clean the magnet off of any debris
http://www.parksoffroad.com/tacomamo...de/cip0335.pdf
p0505 is Idle Air control Valve. Take it off and clean it down. Failure could be from valve being stuck open or closed. Could be a bad line to it or could be a faulty part.
http://www.97supraturbo.com/Trouble%...0Idle%20CV.pdf
nicklp60452
Jul 14, 2008 02:53 AM
