Suspension & Brakes Theory, alignment, spring rates....
H&R civic/integra race v H&R ITR sport spring rates?
Old Apr 29, 2009 | 09:38 PM
nightrider's Avatar
Default H&R civic/integra race v H&R ITR sport spring rates?
Currently, I drive a 92 GSR powered civic si and plan on replacing all major bushings as well as the current tein coilover application.
I have decided the Tokico is the shock I want due to the 5 adj settings. I daily drive my car and snowboad in the winters, yet would like to hit up 3-5 auto-x's per season, if not more.
Its my understanding that a civic or integra H&R race spring will work with my rear oem lca. However, if I go with the ITR sport springs, I need to use ITR rear lca's. After all the research I have done on the various setups, any advice on which springs to get?
I'm thinking ITR H&R sport springs + illumina's unless the rates are not much different than the civic/int H&R race springs. Also, my previous auto-x experiences was with my ITR with oem shocks + H&R sports. I may add a usdm 22mm itr rear swaybar, but would like to get the shock/spring combo installed first.
Good reference I just found too!
Originally Posted by boost junky 71
Here's some info that should be helpful to you. A list of multiple spring rates.
H&R OE - 280F/190R (P/P)
Eibach ProKit - 290F/190R (P/P
H&R Sport - 330F/280R (P/P)
Eibach Sportline - 310F/275R (P/P)
Neuspeed SofSports - 260F/150R (P/P)
Neuspeed Sport - 280F/180R (P/P)
Neuspeed Race - 485F/395R
Progress Lowering Springs - 320F/200R (P/P)
Ground Control Coilover - 380F/280R (P/P) (this is the standard kit and the springs are mildly progressive).
Tokico Illumina Kit - 250/123 (P/P)
Old Apr 30, 2009 | 12:05 PM
nightrider's Avatar
Default Re: H&R civic/integra race v H&R ITR sport spring rates?
I just spoke with H&R and I got the spring rates for the Integra and Civic Race spring.
94-01 Integra Race spring – 460F/360R
92-95 Civic Race spring – 490F/400R
Any advice based on this information on which spring I should get?
Old May 1, 2009 | 07:38 AM
nightrider's Avatar
suspension forum with nobody to chime in?
Old May 1, 2009 | 09:47 PM
vladd's Avatar
the springs are interchangeable between the itr and other integras and civics; it's the rear shocks that're affected by the itr's thicker lca. people have put oem itr springs on different integras. also, i think the koni yellows are supposed to be stiffer than the tokico's if that's what you're looking for. they're 4 way adjustable and last a really long time. i've taken my integra up to the mountains for skiing and did just fine with them on the softest setting.
Pikey
Apr 11, 2006 07:13 PM
CW-ITR
Oct 22, 2005 11:11 AM
B18C5-EH2
Sep 14, 2002 10:41 AM
TaboR
Nov 20, 2001 10:20 PM
nugget8000
Jul 28, 2001 05:31 AM
