Car vibrates alot after axle replacement
Old Apr 29, 2009 | 06:14 PM
Zector's Avatar
Default Car vibrates alot after axle replacement
ok so i replaced both my axles on my dc and now im getting a vibration that mostly happens in second gear low to mid range rpms also happens under kinda hard acceleration....i already took out both axles and replaced them again and made sure all was tight....its getting pretty annoying since its my dd so any help would be greatly appreciated!!
Old Apr 29, 2009 | 06:24 PM
emooheo's Avatar
Default Re: Car vibrates alot after axle replacement
did you use autozone or similar rebuilt axles? if so, that is probably your problem.
Old Apr 29, 2009 | 06:28 PM
Zector's Avatar
o really yea i used autozone axles......where can i get better ones?
Old Apr 29, 2009 | 07:46 PM
Arsenal's Avatar
raxles.com
Very good, with excellent customer service.
Old Apr 29, 2009 | 07:56 PM
MD426's Avatar
I replaced my driver side axle with a Napa rebuilt one and it works perfectly, no problems what so ever.
Old May 21, 2009 | 05:37 PM
94lsrhd's Avatar
Ya i am going to use napa cause even the guy that works at autozone told me not to buy them. They were 70 bucks each there plus 20 core and 40 bucks at napa plus 11 core.
Old May 21, 2009 | 05:46 PM
itslogz's Avatar
I put autozone axles on mine. Same **** you're experiencing, they're crap. I got the new ones too, not remanfs but they just suck.
Ima take them back and try Napa ones and see if that helps, if not ima get some raxles for $129 a piece + $30 shipping.
Old May 21, 2009 | 05:53 PM
racebum's Avatar
you guys basically have this figured out. autozone axles suck. raxles are great and some of the better parts stores like napa or our baxters here in the nw sell, well, not high quality but at least non vibration axles. i have 12k miles on some decent remans with no issues.
Old May 21, 2009 | 05:55 PM
itslogz's Avatar
Thats what im hoping anyway is that napa's work fine. Its my DD not a track car or anything so im not worried about breaking one, as long as they dont vibrate and they work i'll be happy with it. Autozone has a bad rep by now for axles, i just assumed new ones would be fine > reman's
Old May 22, 2009 | 02:14 PM
MeathooK's Avatar
I haven't had any problems w/ my oreilly axle :-\
But if it's vibrating on acceleration, it's the inner joint.
Old May 22, 2009 | 02:15 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If they vibrate during acceleration, that means the inner joints are bad. In many cases they're bad right out of the box, as you have already experienced.
Old May 27, 2009 | 10:22 AM
94lsrhd's Avatar
Just put my napa remans in last weekend and then took the car up a steep hill and the car ran better on then it did before I changed them. Had alittle more power and the car shifted smoother (auto tranny).
Old May 27, 2009 | 10:34 AM
steveo135's Avatar
this what i came in here to post after i read the title
sevwen7
28
Aug 17, 2010 11:21 PM
Gsr94black
Mar 6, 2009 05:48 PM
slkleltlclh
Nov 8, 2006 09:36 PM
jdmskin
Oct 13, 2003 01:04 PM
fred92htch
Jul 10, 2002 02:07 PM
