headlight removal..?
Old Apr 29, 2009 | 05:11 PM
dx_rex's Avatar
Icon2 headlight removal..?
do you need to remove the bumper cover to replace the headlights..? not the bulb the actual headlight..lol!
Old Apr 29, 2009 | 05:18 PM
DC5BOI90's Avatar
Default Re: headlight removal..?
not sure im pretty sure it be hella easier removing the bumper its easy too!
Old Apr 29, 2009 | 05:20 PM
Nimrod23's Avatar
I'm pretty sure you need to, there are screws located under the lights that you need to take out.
Old Apr 29, 2009 | 06:35 PM
ep3man's Avatar
if your talking about an ep then YES! the plastic clips uptop by the hood latch need to come off and there are more underneith. then above the corner lights just pull outward and is should pop right off
Old Apr 29, 2009 | 09:06 PM
odishaw's Avatar
even on a dc5 you need to remove the bumper to access the the bolt on the side of the headlight in the bumper area, and one below the headlight wayyyy the **** in the bumper support!
Old Apr 30, 2009 | 11:50 AM
bdooley3's Avatar
yes you need to remove the bumper its a pain sometimes.
Old Apr 30, 2009 | 11:57 AM
josh's ep3's Avatar
Function > Form
Yes you need to remove the bumper like everyone else said. Don't be intimidated though, it's really easy and don't be afraid to be a little firm when you're yanking on the bumper.
Old Apr 30, 2009 | 02:11 PM
AllCityNemo's Avatar
That's funny I've heard people say its easy but idk I never did it yet
Old Apr 30, 2009 | 03:20 PM
bdooley3's Avatar
Make sure you don't break the clips either. Use 2 flat head screw drivers to pry the tops up. And a 10mm deep socket is your best friend and a philips head also. Its only 3 bolts and 1 screw per headlight
Old Apr 30, 2009 | 11:05 PM
melvin's Avatar
agreed. i was scared too at first. now taking off a front bumper is easy as taking a ****(not when your first wake up though, sometimes its hard)
rattlecannedEF
Jul 12, 2009 12:53 PM
Jer'rome
Honda Civic (2001 - 2005)
May 27, 2007 05:57 PM
evostitch
Dec 20, 2004 10:24 AM
ForceXVII
Aug 29, 2003 11:21 AM
89 CRX SI
May 23, 2002 07:40 PM
