carbon fiber hood
Old Apr 29, 2009 | 03:39 PM
vinceg143's Avatar
Default carbon fiber hood
i wanted to get one, is this a bitch to put on, what is involved in getting the old on off and putting in the new one in, do you need hood pins?
Old Apr 29, 2009 | 04:08 PM
aeros's Avatar
Default Re: carbon fiber hood
is like plug and play...take off ur original hood and put on the cf hood. You might need to adjust your hood latch a little to close it
Old Apr 29, 2009 | 05:23 PM
Stevowns's Avatar
No need for hood pins, all you need to do is take off the bolts off the hood latch which is a 10mm socket I believe ...
Old Apr 29, 2009 | 05:37 PM
vladd's Avatar
hood pins aren't required but recommended.
Old Apr 29, 2009 | 05:49 PM
IntegraCF21's Avatar
Yeah I would definitely recommend hood pins. I didn't feel safe not having hood pins on mine since at highway speed the hood shook a little bit like it wanted to fly up. Also the metal latch is just bonded to fiberglass on virtually all CF hoods so it isn't that strong of a bond and probably gets weaker as time goes on with all the opening and closing as well as just the pressure of holding the hood down.
hondacrx2
Oct 12, 2007 10:16 AM
scabbs
Sep 17, 2007 06:48 PM
ForceXVII
Dec 1, 2003 10:49 AM
chopsgsr
Mar 2, 2003 02:59 AM
1qWiKhAtCh
Jan 28, 2003 10:23 PM
