F2D Mounts for Ek
Old Apr 29, 2009 | 01:45 PM
d1nki's Avatar
Default F2D Mounts for Ek
I have been reading around for awhile now and I cant seem to find out which mounts do I use for this swap. I think I use the d-series t bracket and upper trans mount. What about the driver side mount?
Old Apr 29, 2009 | 08:09 PM
d1nki's Avatar
Default Re: F2D Mounts for Ek
no one knows? I know using the h-series kit from hasport works when using an h-series tranny but idk if it will still work with the d.
Old May 2, 2009 | 05:39 PM
h22ed6's Avatar
you can use your stock mounts for the rear and passenger side, or aftermarket d series mounts i.e. hasport, avid, ect. you would have to custom make a mount for the driver side or use a stock or aftermarket mount like hasport and make a custom bracket that bolts to the block like what qsd has with their plate and mount kit. You might also call up bisimoto and see if he already supplies a mount kit with his adapterplate kit. I have an ef and all hasport mounts are supplied when I bought my plate from him
Old May 2, 2009 | 06:21 PM
d1nki's Avatar
ok thanks
Old Dec 18, 2013 | 07:14 PM
Rodrigo_Pty's Avatar
hi, i have the same question too.
if i have some engine mount like hasports for d series engines.
in the driver side i should use or make my own bracket? or there is an aftermarket alternative out there?
thanks
Rod
Old Dec 29, 2013 | 03:20 PM
Shmallow's Avatar
thanks
Rod
read from above...
you'll need to make your own belt-side bracket for the 6th gen - EJ6/8. reuse all trans. mounts and brackets.
turboblack2door
Oct 8, 2012 03:10 PM
bigD
Jan 9, 2008 07:28 PM
teamvirus
Northern California (Sales)
Nov 8, 2006 08:33 PM
DJ_SaNdOz
Feb 10, 2003 09:10 AM
BigBlockCRX
10
Dec 30, 2001 07:42 PM
