is 91 LS knuckle same as 91 GS knuckle?
I have a 91 GS with a bad wheel bearing and upper bj
I also have a 91 LS for parts.
are there any differences between the 2 models front ends?
I want to get the parts rebuilt from the LS so I dont have to take my GS off the road till I have the parts to swap in, or will the knuckle and uca be incompatible?
I wanted to be sure there wasnt something weird before I started pulling stuff apart
ok, I will look for the empty abs sensor mount on the ls knuckle, otherwise its downtime fun while I get rides to have the bearing and upper bj replaced
thanks
thanks
If your parts LS has ABS then it will work. Otherwise your options are to: Find an ABS knuckle or replace the bad components of the knuckle on your car.
