Rear hatch leaking/need to find part
Old Apr 29, 2009 | 09:49 AM
707the89fu's Avatar
Icon2 Rear hatch leaking/need to find part
Hi i have a 1993 civic HB
and what i am looking for is the seal or weatherstrip that goes around the
window
i look high and low but no luck so
any info would be great
Old Apr 29, 2009 | 09:55 AM
instructor74's Avatar
Default Re: Rear hatch leaking/need to find part
you can't get it it only comes mounted to the glass. And buy the way that is not your weather strip it is a peice just to give the glass a finnished edge
edit: Are you sure that you are leaking around the weather strip? I have never had a leak around the window glass seal unless it was damaged. The place I have seen the most leaks is around the hinge seal for the upper tailgate.
here is what I found
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/rear-hatch-water-leak-2222273/
Here is the exploded view for the rear hatch seal its number7
http://www.hondaautomotiveparts.com/...ry5=LOWER+GATE
Old Apr 30, 2009 | 09:36 PM
707the89fu's Avatar
iam pretty sure it around it
cus i've watch drops fall from it
thanks for the info
that what guess
Old May 1, 2009 | 08:57 AM
thanks for the info
that what guess
you do understand that the peace that you are pointing at has nothing to do with sealing the rear glass I had run without that on the rear glass for over 10 years until I found one in a junked car that the rear glass was broken out of.
Rex89
Jan 2, 2007 06:12 PM
sniperslayer
Jun 4, 2006 09:20 AM
drew2
Jan 29, 2006 04:42 PM
Rextified2003
11
May 12, 2004 09:33 AM
rice_classic
Jan 14, 2004 12:32 AM
