99 civic cd/stereo into 94 civic coupe. Will I need stereo code for the 99 player??
Will i need the code or will this be plug and play. I can figure out the harness portion of this install. I just need to know if this deck will require a code to make it work.
chances are you'll need the code for the 99 player. harness should all be the same. you can plug it in, if it requires the code, it'll prompt you for it. Simple as that.
Cgarrick1
Audio / Security / Video
Aug 28, 2007 09:55 PM
