gaskets ?
Old Apr 29, 2009 | 03:16 AM
95skunkedgsr's Avatar
Default gaskets ?
when most of you guy's build your motors do u go right to the honda dealer for your gaskets. Have any of you used the egay kits?
I was lookin at this. http://cgi.ebay.com/ebaymotors/Honda...1%7C240%3A1318
As u can tell this is my first motor build!!
Old Apr 29, 2009 | 08:38 AM
98vtec's Avatar
moderator emeritus
Default Re: gaskets ?
do it right.
Old Apr 29, 2009 | 04:36 PM
can u buy all the gaskets from the dealer as kit or you gotta buy them one by one for a arm and leg ?
Old Apr 29, 2009 | 04:57 PM
vinuneuro's Avatar
Honda sells gasket kits, but last time I checked at least the Prelude one was more expensive than buying them separately. Buy oem parts from Majestic Honda:www.hondaautomotiveparts.com. It's significantly cheaper than buying from the dealer.
Old Apr 29, 2009 | 06:39 PM
Rocket's Avatar
It's gonna work fine if properly installed.
Production Engine Rebuilders ("PERs") use them.
Kinda the same argument that a 99 cent Autolite spark plug works as well or better than a $35 OEM iridium plug (or $1,000 Nologee sparke plugs).
Old Apr 29, 2009 | 07:41 PM
ruffrhyder's Avatar
I've used ebay gasket kits from CNS for customer's who were on super tight budgets and they have held up well. One is at 70k miles, several at 50k miles and no leaks yet. I just use a felpro head gasket instead of the head gasket that comes with the $60-70 CNS kit.
Old Apr 29, 2009 | 08:15 PM
well budget isnt a problem because i would just save till i have the amount to get what I realy need .. But i didnt want to spend extra money on a spot that didn't need it (IF that makes scense)like some oem parts cost way more then what it should , If a aftermarket remake will do the job just as good for a cheaper price (cam seals,o-rings and other little things)
Old Apr 30, 2009 | 08:24 AM
ruffrhyder's Avatar
Here are some OEM gasket prices,
http://www.hondapartsunlimited.com/s...itch=&hidIrno=
Old Apr 30, 2009 | 03:38 PM
so the full kit is 264.70 thats about 200 more is it realy worth that much more ?
Old Apr 30, 2009 | 05:11 PM
ruffrhyder's Avatar
In my opinion, not all the oem gaskets are worth the price. Like MOTU already said, if installed correctly, even aftermarket brand gaskets will work. If you do get the ebay kit at least get a reputable head gasket such as a felpro or oem head gasket, perhaps the same can be said for the rear main seal as well.
Old Apr 30, 2009 | 11:13 PM
thanks for clearing will be going to dealer for rear main seal and else where for head the bore is gonna be 82mm so oem is to small read somthing about creating hot spots and all
judd_123
Oct 17, 2010 09:11 PM
RACEPAK
Jul 18, 2007 07:07 AM
redsolturbo
Dec 2, 2006 06:42 AM
abnaasefmb
Sep 7, 2006 04:18 PM
Mike95lude
May 12, 2004 09:51 AM
