Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Anyone run Hankooks?
Old Apr 29, 2009 | 02:46 AM
Conan the Destroyer's Avatar
Default Anyone run Hankooks?
are any of their higher end Ventus' worth a ****?
Old Apr 29, 2009 | 04:25 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Anyone run Hankooks?
Hankook makes a lot of tires with the Ventus name on it (just like Bridgestone does with the Potenza name, Kumho with Ecsta, Goodyear with Eagle, etc) - everything from crappy but cheap all-season tires to full race slicks. The only two tires anyone talks about (on this forum, anyway) are their Ventus R-S2 Z212 street tire, and their Ventus Z214 R compound track tires.
For street or street/track use, the R-S2 Z212 has fallen behind the "extreme performance" tires from other manufacturers in performance, which is why it's being discontinued by Hankook. Its replacement, the R-S3 Z222, is just hitting the market now; so far the only Z222 size of interest to most of us is 225/45-15. I would assume the Z222 will be reasonably competitive with other such tires like the Bridgestone Potenza RE-11, Kumho Ecsta XS, Dunlop Direzza Sport Z1 Star Spec, and Toyo R1R. (The Falken Azenis RT-615 is similarly starting to fall behind and I wouldn't be surprised if Falken is working on a replacement to be introduced in the near future.)
For track use, the Z214 has the same tread pattern as many other R compound track tires, with two longitudinal grooves for the tread pattern. It's decent, as most R compound tires are these days, but I haven't seen a lot of people using it at the track.
Old Apr 29, 2009 | 07:45 AM
tronic's Avatar
The RS-3 street tire is now available. Limited sizes, but there is a 225/45-15 which would definitely be my choice for 23" OD street tires for track days. I've done many track excursions on even old worn out RS-2's and they hold up great. I like the flippable tread pattern, too.
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
I haven't seen anyone use Hankook R-compounds for autox or track, personally.
Old Apr 30, 2009 | 10:55 AM
wakaranai's Avatar
Sweet. This is news to me! It's interesting to see most manufacturers making very similar tread patterns for this class of tire now.
Old Apr 30, 2009 | 11:02 AM
The G-Man's Avatar
Note that the RE-11 is radically different, but all the others seem to revolve around the RE-01R
Old Apr 30, 2009 | 11:06 AM
wakaranai's Avatar
Yeah, did the MX come out before the RE-11?
Old Apr 30, 2009 | 12:40 PM
The G-Man's Avatar
Yes it did, to the public market. But who really knows when those tread designs were set in stone.
Old Apr 30, 2009 | 05:01 PM
this was the most helpful thread response i ever received. thanks. im looking into all of the 225mm hankook choices now. they are running a sale on them where i am (japan), thats why i asked.
Old Apr 30, 2009 | 05:55 PM
ive been reading up on them and it seems hankook is pretty creative with their sizing. laid next to a rt215 falken they are pretty identical on a 7j rim.
Old Apr 30, 2009 | 08:45 PM
vietnameeh's Avatar
width means nothing .... compound is more important
Old Apr 30, 2009 | 08:54 PM
SquirtleSquadEf9's Avatar
i say stick with the KUHMOS!!!!
Old May 4, 2009 | 04:55 AM
divinition's Avatar
i'm running the Z214s now with bout 4 heat cycles and they're still great! stiff sidewalls and you can tell when they're reaching their limit, so it's pretty predictable.
i'm running the hard compounds that were on sale/clearance and probably still are if you look hard enough.
$80/tire for R-comps are a pretty bargain to me. 205/50/15
Old May 5, 2009 | 12:53 PM
livesockets's Avatar
New User
One of my friends will be testing a set of the new hankook RS3 at the track this week. will let you know his opinion of this tire. From what I've heard it should be right up there w/ the other tires in its class.
Cooper The Tire Rack
Jun 18, 2009 09:15 AM
civic-one
May 1, 2009 07:59 AM
jsayoc
Jan 5, 2008 05:38 PM
slacker~J
Feb 6, 2004 06:35 AM
smokin rubber
Apr 25, 2002 11:53 AM
