Can u pass smog with low compression pistons in gsr
Old Apr 29, 2009 | 01:13 AM
_inline4turbo_'s Avatar
Default Can u pass smog with low compression pistons in gsr
Question: me and friend been debating: CAN U PASS SMOG WITH LOW COMPRESSION PISTONS IN GS-R? Sorry sounds like a noob question but im about to boost my car, but i have that fear of getting pulled over one day by a PIG and getting that Ref tix and having to put the car back to stock. so if i do get the REF tix can i pass smog with low compression pistons.
The setup up i have:
stock gsr head
low compression manley pistons 9:1 with stock sleeve no bore
itr intake manifold
dc headers
2.5 pipe with cat
aem CAI
********TELL ME WHAT U THINK THANKS*********
Old Apr 29, 2009 | 02:11 AM
DcYo's Avatar
Default Re: Can u pass smog with low compression pistons in gsr
yes you can just use a stock ecu + stock cat. Make sure ure running a stock fpr and carb legal components
Old Apr 29, 2009 | 06:26 AM
Schister66's Avatar
Man U FTW
You should be able to. I can't recall exactly, because it's been so long since my last automotive tech class, but i believe that lower compression yields a more complete burn of the fuel...that may be totally ***-backward though. With the proper emissions garbage in place, you should be able to pass no matter what...the compression isn't that terribly low anyway.
For the record, the lack of emissions laws is one of the few things that ND has going for it. I can drive around all day with my turbo setup in plain sight and no cat to speak of...there isn't a thing the popos can do. I did actually get pulled over and questioned about having a cat...the cop and I looked under my car (not an easy task) and i pointed out my "cat" to him...aka my flex pipe on the downpipe. Then i was on my way
Good luck
Old Apr 29, 2009 | 09:41 AM
1043
Old Apr 29, 2009 | 09:44 AM
Good luck
haha nice thanks a lot guys for the advice
Old Apr 29, 2009 | 09:48 AM
258
Old Apr 29, 2009 | 01:59 PM
Any more advice are appreciated!!! Anyone else with stories or ideas?
Old Apr 29, 2009 | 02:41 PM
TunerN00b's Avatar
Type-R intake on a GSR head?
1) I didn't think they bolted up.
2) That will fail the visual.
For the test itself, I'd consider using low octane if it runs with stock timing without detonation.
Old Apr 29, 2009 | 08:14 PM
914
Old Apr 29, 2009 | 08:21 PM
lilo_goki's Avatar
the lower the compression the more chance of passing.
Old Apr 29, 2009 | 09:15 PM
boostdc211's Avatar
yes sir u can
Old Apr 29, 2009 | 09:44 PM
thanks guys has anybody tried it yet?
Old Apr 30, 2009 | 08:06 AM
backyard_concepts's Avatar
all signs point to yes
Destructive-
Apr 11, 2010 05:23 PM
aznwash3wboi
Aug 2, 2007 12:44 PM
aznwash3wboi
Nov 10, 2005 08:44 AM
TypeRPaul
Mar 20, 2004 02:44 AM
asianautica
Mar 26, 2003 09:49 AM
