jdm suspension spec r m coilovers
I got a set of these from a friend a few weeks ago. After installation the suspension was a lot stiffer compared to my old set up which was Tokico whites with Eibach pro springs. The shock is about 3 inches shorter then stock, orginally I was going to get extended top hats but with these there is no need.
Springs are way stiff, but that is exactly what I wanted. You better get some tires with stiffer side walls or your ride will be bouncy IMO.
On a side note you know these are made for an EK suspension right?? Just making sure since you posted this in the Acura Integra forum.
square_1
Oct 9, 2007 11:56 PM
