CRX seat HELP!!!!
Old Apr 28, 2009 | 09:50 PM
CRXguy_88's Avatar
Default CRX seat HELP!!!!
I would like to know if seats from a 89 si crx would bolt straight up (with 89 crx rails and pan on 89 seat) to a 90-91 crx. i believe i have a dx.. but not sure if its a 90 or a 91 haha but any help would be great i need help fast because i found amazing seats and i just wanna see if theyll fit. thanks
Old Apr 28, 2009 | 11:25 PM
crxcess's Avatar
Default Re: CRX seat HELP!!!!
you can't go look at them and compare?
Old Apr 29, 2009 | 12:12 AM
hushypushy's Avatar
89 Si seats will bolt right into a 90/91.
Old Apr 29, 2009 | 08:30 AM
k20rex's Avatar
88-89 seat rail are different from 90-91 seat rail and they will not bolt right in, but you can make it work with a little work, what you would have to do is swap out the seat pans beteewn the two and that will make them bolot right in your 90
Old Apr 29, 2009 | 09:16 AM
hushypushy's Avatar
For hatches, yes, for CRX's, no. The seats work like this, and it has to do with pillar versus door mounted belts:
88 CRX = 89 HF = JDM/Canadian CRX = 88/89 US hatchback
89 DX/Si = 90/91 CRX
So, if he has a 90 DX, then 89 CRX Si seats have the same rails and are a direct bolt-in. However, 89 Si hatch seats will not work.
Old Apr 29, 2009 | 11:49 AM
CRXguy_88's Avatar
i cant just look and compare. the seats i want are like 120 mile away and im not even at home to look at mine cuz im at school so i was just asking
Old Apr 29, 2009 | 11:52 AM
CRXguy_88's Avatar
and also the seats i want are from an 89 SI and im the one with the 90 or 91 base or "dx" so they will fit...?
Old Apr 29, 2009 | 12:34 PM
KoDKingVegeta's Avatar
The difference from the SI to the DX or STD is features, such as seats and motor and interior. So if you do a seat pan swap (if the rails dont line up) then it will fit.
Old Apr 29, 2009 | 01:03 PM
Canadian_EF's Avatar
school is a great place to look up honda related things... seriously. i am at school right now.
but yeah, you will have to do a seat pan swap... or make a custom bracket.
the bracket would bolt to the seat, and then the rails from your 90-91 would bolt to it. it is easiest to do this method for any seats, really. i plan on doing this so that my 97 teg seats can go in my hatch... but i gotta learn to weld.
Old Apr 29, 2009 | 01:07 PM
redsi89's Avatar
i dont know how much different the seat rails are from dx to si but I put 90 si seats into my 89 si with no modification.
818blue818
21
Jul 24, 2009 02:54 PM
Mr. EF
Oct 18, 2008 08:58 PM
type Gendy
Jan 6, 2005 03:14 PM
SlowMotion
Feb 4, 2004 12:49 PM
Hondasaurs
Dec 6, 2002 05:28 PM
